โFeb-28-2017 05:39 AM
โMar-01-2017 08:13 AM
โFeb-28-2017 10:27 AM
โFeb-28-2017 09:22 AM
โFeb-28-2017 08:14 AM
โFeb-28-2017 08:13 AM
โFeb-28-2017 07:26 AM
DeanRIowa wrote:horton333 wrote:
I have a similar issue, I'm thinking of something like this.
Make something to clip it on, and recharge in the day. Running a wire may work better, but this is also portable so it can go outside.
there are various types, cheap enough if it doesn't work then ....
Interesting I looked at that very light, only not sure a place exists to clip it. I will check once I pull trailer out of storage.
thanks,
Dean
โFeb-28-2017 06:45 AM
coolmom42 wrote:
The light in the link above would work, if you have a shelf that the clip will fit on. If the shelf is pretty high, the light may spread out enough to bother your wife. Look for one that has a long neck you can pull down to position.
If you are using a tablet or e-reader with its own light, you just need enough of a night light to see what you are generally doing. A small plug in light would work for that. It would be down low enough that it wouldn't be in your wife's face.
โFeb-28-2017 06:41 AM
โFeb-28-2017 06:08 AM
โFeb-28-2017 05:49 AM
DeanRIowa wrote:
I would like some ideas?
