Dead Sharp Microwave
JaneNLee
Does anyone know where or what substitution I can buy to replace a Sharp Carousal Convection Microwave Combo . Present model is a 1994 Model R7A85.
Inside of door cracked glass.
Thanks for all you answers to help.
Happy RVing
Never RV with anyone crazier than you!!
15 REPLIES 15
robatthelake
That Glass should be replaceable.
Rob & Jean
98 Dutch Star Diesel Pusher ..07 Honda CRV AWD
mmiille
I called sears and they sent a repairman out for $80 and he found a $20 switch that was bad. 20 years old is pretty old though.
Martin & Cheryl
40 Foot 2009 Damon Tuscany 4076
Cummins 360, Hyundai Santa Fe
Full timing since 2010.
MrWizard
Moderator
Moderator
I've Never seen a 36" wide residential MW
Our new one, well three years old, is 29.5" , the cabinet opening is 30" wide
Every MW in the store was 30" or less
The one that died was a 1995 model and 29.75" wide
I can explain it to you.
1997 F53 Bounder 36s
Cummins12V98
MrWizard wrote:
JaneNLee wrote:
Tried that and it is a 'built in' over the range/oven. Any salvage yards? you know of?
Thanks for your help
when our GE over the range top convection/MW died
i went to Home Depot and bought a replacement
they are all the same size within a fraction of an inch width
depth and height can vary, but they will all fit in the same hole under the cabinet..over the range
all come with a NEW mounting bracket
Not all microwaves are the same width. The one that came in our Avion Platinum was 30" NOT 36".
Not so easy to find so I modified the cabinet and installed a Sharp.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
MrWizard
Moderator
Moderator
Cummins12V98
If you like your microwave these people may have the replacement part.
repairclinic.com
TucsonJim
Cuffs054 wrote:
Jim, I had to laugh. The matching trim kit cost more than the MW! Nice looking unit.
I saw that after I posted the link. I almost choked. Hopefully, her existing trim will work.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
Cuffs054
JaneNLee
Thanks, I appreciate all your help Thank you all
RV_CONUS
In the last 8 years I replaced mine twice.
One online through Walmart
One online through Home Depot
The first one was the exact original model,
the second one was an updated model.
Measure, match and switch. It's an easy process, and the original hardware was usable.
2006 Allegro Open Roads 34WA
2015 GMC Terrain
2009 Blue OX Aventa LX
2009 Brake Buddy Classic
JaneNLee
Thanks Jim I will check it out. And it did last 20 years- 4 of them full timing.
Thank you for your help.
Will be driving from Vegas to Illinois soon- will toot for you as we go thru Tucson.
Thanks again for everything. Your profile is great nice truck and 5th wheel.
Happy Rving
Jane
TucsonJim
Wow - It lasted 20 years. That's great.
I did a little research for you.
Your model measures 20-1/2" Wide, 12" High, and 18-1/8" Deep.
I found an inverter microwave on Amazon with nearly the same height and width, but a little less deep which shouldn't be a problem.
Panasonic Microwave
It is 20-3/8" Wide, 11-7/8" Tall, and 15-5/16" deep.
Jim
sch911
Nah it's not built in. There are dozens of replacements out there. Just look for an over the range microwave. Home Depot, Lowes have many that would work...
OEM Auto Engineer- Embedded Software Team
JaneNLee
