โNov-15-2013 02:52 PM
Moderator edit to re-size pictures to forum limit of 640px maximum size.
โAug-14-2016 07:49 AM
โAug-13-2016 07:43 PM
โAug-13-2016 07:37 PM
โAug-08-2016 09:03 AM
โNov-18-2013 05:37 PM
โNov-17-2013 04:25 AM
โNov-15-2013 10:29 PM
wanether wrote:
Here it is 45 degrees and raining in Portland and I'm replacing the vinyl trim inserts on my Jayco. Installing the new stuff was slow going, I would pinch about 12 inches and then squeeze it in the channel, the temperature outside wasn't helping much either. After about 30 minutes of struggling and cursing I figured there had to be a better way.
I learned that the trick is to place about a 12 inch run in the bottom of the channel and then run a plastic tool along the top edge. Worked like a charm. The key is to angle the tool in the direction you'll be going, it helps with keeping it in place, see photos. I still had problem in the corners and ended up have to cut notches on the inside part of the curves, still didn't look 100%. Probably a combination of cold temps and maybe poor product, I used "RV Designer" insert from Camping World. The plastic tool is something I picked up at Harbor Freight, they come in a pack of assorted sizes.Moderator edit to re-size pictures to forum limit of 640px maximum size.
โNov-15-2013 06:25 PM
โNov-15-2013 05:13 PM
โNov-15-2013 04:44 PM
โNov-15-2013 04:29 PM
โNov-15-2013 03:02 PM
