โApr-14-2015 09:01 PM
โApr-19-2015 06:04 PM
โApr-17-2015 09:28 PM
โApr-16-2015 08:26 AM
โApr-15-2015 03:50 PM
Chris Bryant wrote:
It depends on the resistance- it will draw from the higher voltage source until the resistance in the circuit gets high enough the voltage drops to equal the battery voltage.
I believe you're over thinking this, and that the instructions are not very good- they spec a "25 to 40 amp" feed, and recommend using #12 wire. 25 amp would call for #10, and 40 amp would call for #8 minimum, purely on load carrying capacity (ignoring voltage drop).
I wouldn't sweat it- just make sure the factory circuit is in good shape, the plug is clean, and all connection tight.
โApr-15-2015 10:41 AM
โApr-15-2015 09:39 AM
โApr-15-2015 07:25 AM
โApr-15-2015 06:53 AM
โApr-15-2015 06:44 AM
โApr-15-2015 06:43 AM
โApr-15-2015 06:35 AM
โApr-15-2015 04:35 AM
โApr-15-2015 04:11 AM
โApr-14-2015 09:16 PM
