Full size oven??
BobandShaz
Was wondering about a full size oven. WE are thinking about maybe full time RV and the wife bakes State Fair winning cakes and pies I would sure hate to give those up ")
Bob and Sharon
2006 Winnebago Sightseer 29R Ford F53. Roadmaster Eagle 8000. 2001 Ford F150 7700 4x4. Still shopping for toad brakes. FMCA F286179
15 REPLIES 15
daffy54
why not try using an electric roaster oven, and store away when not needed! my 22 quart one works great for this...
travelrider73
Very interested in this too. My wife uses the oven in our stick house all the time, not for baking, but for cooking things like prime rib, leg of lamb, roasting veggies, etc. I have heard that people struggle to get good results from the standard RV ovens. Is that true? Can you get good results from a gas RV oven? With regard to convection, I can't imagine a convection microwave can make a beautiful rare prime rib... Maybe I'm wrong, but I'm struggling to believe it.
So, has anyone retrofitted a 24" apartment gas range into their RV? If so, I'd like to hear about it - pics would be even better.
Our retrofit would be into a 5er, and not a park model with big sliding glass doors, so - not entirely sure we can get one through the door. Measuring tape time...
colliehauler
loulou57 wrote:
You could get a gas "full size" oven/stove and have it converted to run on propane instead.
Since full size is generally 30", ( you can get a smaller 24" ), you need to have the space. I wonder if one would fit through the rv door.
I have seen a lot of park models with a 24" stove installed.
Old-Biscuit
Getting a 'residential' size oven into RV is the biggest problem.
Modifying the cabinet/counter top is not difficult
Natural gas ovens can run on LP...just have to change orifice.
loulou57
moonlightrunner
I have friends who converted a school bus. They put in their 30" lp gas range and run the 110vAC stuff (ignitor and electronics) off the inverter so they can still bake if the power goes off. Their thoughts were the largest rv range required a 24" cabinet space to install. The residential slide in range required 30". Only 6" more. Since they are fulltimers and like to cook/freeze meals, they opted to keep the residential range. They say the residential range cooks far better and uses 1/4 of the lp that their rv range did plus they cook far more now and still only go thru a 20 lb tank in 3 or 4 months. Pretty good considering how heavily they use the range. It's enough to convince me to convert a school bus and build it like they did, using mostly residential appliances, etc. They put the burner grates, spreaders and caps in the bottom drawer (modified to lock) while traveling.
Lynnmor
If you can alter the cabinet to gain 4 to 5 inches below the oven, then it should be an easy swap.
hitchup
I'm a baker, but quit baking much when we got an RV LP oven. Instead, I used it for pan storage. Then we upgraded the RV which had no LP oven, but a GE Micro/Convection.
Since then, I've done turkeys, pies, cakes, muffins, biscuits, cookies and my homemade lasagna. Wouldn't use anything else.
2014 DRV Mobile Suite Estates 38RSB3....our custom home
2014 Ford F450 KR CC 4x4......his office
2015 Lance 1172 TC.....mobile Motel FOR SALE
Working Fulltimers since 3/2005
"Shoot for the Moon! Even if you miss it, you will land among the Stars."
ktmrfs
Desert Captain wrote:
When I referred to a "full size" oven I was talking about an "RV" full size oven.... (and yes it could be a bit of an oxymoron), this is an RV Forum...right? Never had any problems with even, consistent temperature control but adding a small thermometer will keep it honest. :C
Ours came with the "small" oven, 17". After a bunch of futile cooking attemps, and not enough cooking room DW agreed to buy a "full sized" oven "21 inch". took a little reworking but DW says, and I agree, that the difference in cooking quality is HUGE. Much easier to cook evenly, better results, seldom need a pizza pan to spread the heat around.
Did need to do a temp check on the oven vs. knob and relabeled the knob to match actual oven temps, they are known for being off quite a bit. Our 17" and new 21" read between 25 and 40 degrees low depending on the set temperature.
2011 Keystone Outback 295RE
Desert_Captain
sch911
An LP RV size oven is doable, but there are many stories about uneven cooking and overall poor performance. A full home size oven, never seen one in an RV.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
past-MIdirector
I've only seen a full home size range in one park model. In an RV you'd need at least twice the space to put a home size oven in and would still need a cook top. The wife does a lot of baking and has no problem with the RV size. I added another rack and pizza stone to the oven for more even heating.
doxiemom11
A convection oven may work better than the RV gas ovens. It would be a problem to have a regular oven unless you get a gas oven that runs off propane. My parents did have one in a travel trailer years ago, but I'm not sure how well it did or didn't work for them. I never heard any comments regarding the oven.
Desert_Captain
Unlike many here I would not own an RV of any kind without a full size oven. Just too many delicious meals that can only be made in the oven (we are currently home but I am doing Prime Rib, a two bone 5 pounder this afternoon and will be repeating this favorite in a couple of weeks up at Zion). I don't do the baking thing but my bride does and her banana nut cranberry muffins and brownies are not to be missed. A lot of rigs come with a combo Convection/Microwave which will work well too. :C
