โDec-18-2017 08:15 AM
โDec-29-2017 07:59 AM
โDec-28-2017 09:50 AM
โDec-28-2017 08:02 AM
โDec-28-2017 04:35 AM
westend wrote:
What I did for my travel trailer: Bought one of the cheaper vinyl laminated composite planks from Lumber Liquidators, on sale. It is 8MM thick, IIRC. Used a very high grade underlayment underneath the plank.
โDec-27-2017 07:36 AM
โDec-20-2017 04:36 AM
โDec-19-2017 05:06 PM
wiredgeorge wrote:I operated a flooring installation company for about six years. Let me simplify this for you: Don't trust the adhesive on any flooring product.Johno02 wrote:
We redid our class A with Allure flooring, and had no problems. Just do not glue or staple it, as it needs to expand and contract some with the weather.
Has your RV sat in temps lower than 55 degrees and higher than 85 degrees when not in use? I am thankful that folks have chosen to answer and supply their opinions but I was really looking forward to hearing from someone who has actually used the stuff. I did read the manufacturer's warning about voiding the warranty if temps were out of range but not sure that I care about the warranty all that much. thanks wg
โDec-19-2017 03:21 PM
โDec-19-2017 01:31 PM
โDec-19-2017 06:46 AM
jplante4 wrote:wiredgeorge wrote:
Looks great. I know to let a space for expansion and thought to use 1/4" round above it to hide the gap. Did you consider this or is the gap just not noticeable enough to be an issue? Thanks wg
1/4 round will work fine. I used the pre-finished plastic stuff with a little profile. Just don't nail the 1/4 round through the vinyl. Either nail it to the sidewall or double-stick tape it to the flooring.
Like Frank said above, be fanatical about letting it float.
โDec-19-2017 04:40 AM
โDec-19-2017 02:49 AM
โDec-18-2017 05:22 PM
โDec-18-2017 02:53 PM
โDec-18-2017 12:59 PM
jplante4 wrote:
I've had Allure in the coach for 3 seasons now, stored outside in New England and it hasn't moved. It looks as good now as it did when I put it down in April. We've already been down into the 20s which is as cold as it gets here.
IMHO, you have problems with Allure or any vinyl when you don't let it float. I made sure there was an 1/8th inch space all the way around and I didn't nail or screw anything through the vinyl into the subfloor. I cut around things like the TV cabinet, the copilot seat and the couch legs and mounting brackets, and I used double stick tape to stick down the molding. I put red rosin paper between the subfloor and the vinyl as well.
This is what it looked like right after installation. Looks the same now. You can see the space inder the TV cabinet on the right where I put it up on 1X2s and cut around them.
