โJul-11-2018 04:22 AM
โOct-09-2018 08:23 PM
โOct-06-2018 09:10 PM
F-TROUP wrote:Cummins12V98 wrote:
Other than spending much more money please tell me what is functionally better about the MORryde product compared to my steps?
When your rivits brake your steps will colapse with you on them. The OP should have gone with the 4 step model.
โOct-06-2018 09:42 AM
That happened to me. The top rivet broke on one side as I was going down on the steps. We had the heavy duty steps like the ones pictured. However they were about 11 or 12 years old when it happened while were were snowbirding in Florida. I replaced my steps with the Glow Step Revolution from TorkLift. They are rock solid and work very well. ๐
Barney
โOct-06-2018 08:24 AM
โOct-05-2018 06:09 PM
โSep-24-2018 03:46 PM
โSep-22-2018 06:07 PM
โSep-22-2018 06:04 PM
โJul-14-2018 03:47 PM
Cummins12V98 wrote:
Another thing I don't like about the MORryde steps is once you hit the ground you better keep stepping away from the steps or if turning you may trip on the extended legs.
โJul-14-2018 08:01 AM
Cummins12V98 wrote:
"The moryde has a grab handle and yours doesn't. Having a grab handle can make all the difference to preventing a fall "
This is true but I still have the handle that's attached to the side of the RV. It would be very easy to clamp on another hand rail if needed on mine. Thankfully I don't need rails, YET!
There are different grades of steps as to how stable they are. Mine are the heavier duty ones and have very little movement compared to the others.
โJul-14-2018 07:31 AM
โJul-13-2018 08:11 AM
โJul-13-2018 06:18 AM
โJul-12-2018 11:01 AM
