Installing a MorRyde Equalizer
Vintage465
Getting ready to install a CRE3000 setup with wet bolts and shackles. My thought is the bolts should have the hole that provides grease facing down..............right?
Thanks
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
3 REPLIES 3
Lynnmor
If the grease hole is installed on the loaded side of the bolt, the hole will be closed and almost impossible to get grease in. Of course the loaded side is where the grease will do the most good. Do not expect the bolt to rotate enough to distribute the grease. Injecting grease on the easy (unloaded) side will result in a quick trip in and then out the clearance. My suggestion is to grind a groove in a figure 8 on the inside of the bushing so that grease will travel and distribute on the load side. That groove should not be very deep because the bushing is already thin and it does not need to be pretty. A Dremel type of tool with a small ball shaped cutter is ideal for this operation.
Here is a visual of what I am talking about: examples
Vintage465
gdweb wrote:
grease hole should be at either the 3 or 9 o'clock position.
from morryde pdf:
the grease zerk
may be installed to the inside or to the outside, this
is done at customer preference. Note the grease
exit hole location on the bolt, this should face
sideways to allow for ease of grease flow
Thanks! I recall one person really cursing a lot when he couldn't get grease in it no matter how he jacked the trailer up and moved shackles and springs. Anyone ever sliced a narrow slot down the length of the bolt where the hole is to spread the grease?
V-465
gdweb
from morryde pdf:
the grease zerk
SEMPER FI
Gary & Diane
Ky
2020 F250 King Ranch 6.7l FX4
2013 Sundance 3270res
