Heat cable typically draws 5 watts/', so 50' is 250watts. Waterbed heaters? I think about 150watts each. Thats 800 watts when all are on at the same time, or > 6 amps @120 v.
Now remember heat goes up, so this heat will give you a warmer floor, thus rig. It aint lost heat.
I cabled those heaters under my sink so that when on the road, I plugged them into my 1500w inverter. With the truck running to power the inverter, furnace on at 50 I drove through weather of -20f without freezing.
As soon as I had shore power, I'd switch the heat cables from the inverter to a 120vac plug. Never a problem with overloading the 30 a service.
The pvc material I used to thicken the frame to acommodate 1 1/2 foam is home trim for garage doors, 'brick mold' or similar split on a table saw, like you find at any good home building supply. Attach to the frame with long sdst screws, the type with 'wings' to bore out the wood before hitting steel. Attach the coroplast to the pvc with ordinary pan head wood screws through a metal holding strip that spreads strength and seals it to the frame. Caulk it well to seal any gaps.
Critical to living in an rv in extreme cold weather is to vent moisture, dehumidify to prevent condensation in the walls and ceiling which defeats the best insulation, will rot your rig.
Coroplast in one piece, I had to order then from an rv dealer.
Do it this way,skirting is a waste of money and will not do you half as good of job.
BTW, pm me. I know a bit about ND Bakken
Max,
retired welding boss, HC Price , ua 798 ,254
