LED strip light install
sjturbo
Finally done. Very tedious but clean. Remote sensor is in the running light.
10 REPLIES 10
Lenny_K
Remotes are easy to find and buy on Amazon and are real cheap.
Lenny and Ros
2009 Chevrolet Silverado 3500 LTZ Duramax 4x4 CC Dually, Banks Speed Brake
2012 Montana 3400 RL 680 Watts Solar, 440 Amps of Batteries, GP-ISW2000-12 Inverter, Trimetric 2020, EMSHW50C, Sailun Tires
sjturbo
Nope! Hope that does not happen. But should it I think I can figure out something.
4x4van
Do you also have a manual switch for if/when you lose or misplace the remote?
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
bob213
Thank you for the info. Nothing better than directions in English!
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
sjturbo
Thanks for linking!
I connected directly to an open 12V circuit on my converter > 14g silicone wire to the terminal block > terminal block to LED receiver > LED receiver to 16' LED extension via internal channel for the awning power > to LED light strip, (siliconed connection). Located the hole and connection for the running light. Drilled a small hole in the running light plate and ran the remote sensor to the hole. Done. I left out the 2hours plus that I used an electrical fish tape to run the 16' extension through the horizontal frame channel that was used for the awning power. Hope this helps.
bob213
Looks good. Did you hook directly to 12v? Can you do away with the AC to DC converter?
sjturbo
This should include all the parts I used. Except for the 9v adapter cable which I had from my guitar pedal spares.
LED Strip
https://www.amazon.com/gp/product/B07GB5RMC4/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1.
https://www.amazon.com/gp/product/B01G6Q9S54/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B07FMTCHC1/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B01CG2HI0E/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Couple of additional pics
dalenoel
What parts did you use?
03 Monaco Neptune 36PBD DP - 18 Focus Toad
Wife, myself, and Oreo the Malshi
Helmsey
Looks good!
KK4PFX
2015 Chevy 3500HD LTZ Dually
2013 Sandpiper 365SAQ
