Oxygenics Shower Head Shutoff
4aSong
Recently installed the Oxygenics Shower Head from Camping World and the shut off that came with the unit constantly dribbled water when the valve is shut off. We solved this problem by installing a flow adjuster Lasco # 08-2469 ($5.29 at Ace Hardware) in place of the shut off valve provided and solved the dribbling shower head issue. We boon dock and could not see wasting water unnecessarily. Hope this helps those who want to eliminate the constant dribbling.
M & N
Tundra TRD V8 4x4 w/Leer Shell
EU2000i * Prodigy * McKesh * Trek * Renogy * ENU
26 REPLIES 26
tenbear
miatared wrote:
tenbear wrote:
I bought this cut-off valve. It cuts the flow off completely or any reduced flow you want.
Siroflex plastic flow control valves (these are complete shut off) are available in Chrome or White....
Thanks for this. That would do the trick.
Just to figure out a shipping cost to Toronto, that will not have me take a 2nd mortgage :h
I just looked at Canadian Tire and found this. Looks like it woud do the job.
2010 Subaru Impreza Sedan
wif
Here's what I used:
Shutoff valve
Doug & Trish
Scooter the camping cat
2011 Ford F150 5.0 SCAB
2009 R-Vision TS21RBH
Honda EU2000i
tenbear
I didn't notice the Toronto location. Check the local Home Depot equivalent or Canadian Tire. Maybe they have something.
miatared
tenbear
miatared
Mine didn't ship with a cutoff valve. Any ideas of what I could buy to provide that Navy shower feature?
Thanks.
wny_pat1
I think I was the last guy to finally install a Oxygenics Body Spa Shower Head, version v2.11, adjuster twist valve in head (old style). We just did two showers in a row without running out of hot water. I was amazed that this was possible. I mean, we actually used the hot water and not a Navy shower!
โ€œAll journeys have secret destinations of which the traveler is unaware.โ€
Dtaylor
I didn't put the shut off on mine when I installed it. With the gas/electric we can each get a good 12-15 minute shower with the water constantly flowing. Now, if I were to stay somewhere with no sewer connection I would have to use it to keep gray tank from filling
Our Travel Blog
2018 Premier 29RKPR
2014 Ford F-150
Steve_S1
Bill.Satellite wrote:
The cut-off is designed specifically to trickle water so you don't get a shock of too hot or too cold water. It may not be what you want, but that's why it does it.
Thanks for posting this as I never knew that and I thought I was going to have to buy a new one.
2010 Cougar 25RL
wmoses
Agreed. Also I like the trickle because it allows me to re-wet my hands as I soap up.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Ed. | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra 1500 SLE 5.3L 6-speed auto | K&N Filter | Hypertech Max Energy tune | Prodigy P3
_
rav
we did the same thing, we don't have much of a temp change.
Bill_Satellite
Can't we all just get along?
