? Removing Oxygenic Flow Restrictor
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Jul-29-2019 12:39 PM
How do I remove the flow restrictor in an Oxygenics 'Fury' shower head? It doesn't appear to be able to be popped out like all the other shower heads I've worked on. All the info I found on www refers to the super-easy-to-simply-pop/pull-out restrictors.
DW had me replace OEM shower head with an Oxygenics. Sprays better than the OEM did with the flow restrictor removed. Not much, but better. However, still not good enough, not enough flow/pressure to make the pulse function work properly.
Labels:
- Labels:
Seeking Advice
3 REPLIES 3
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jul-30-2019 10:32 AM
Thanks!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jul-30-2019 09:59 AM
+1 on the drill bit.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Jul-29-2019 01:04 PM
Oxygenic Tech Specs
The internal components are constructed of injection molded Delrin acetal. The pieces are machine pressed into the base and cannot be removed with a straight pushing or pulling force of less than 100 lbs
Use 1/4" drill bit and enlarge the restrictors....they are rated at 2 gpm
