โMar-03-2017 09:52 AM
โMar-18-2017 05:28 AM
SoundGuy wrote:
I just don't see how tapping "2 holes in the top of jack tube" allows rotating the head. :h
BarneyS wrote:
It depends on what brand of tongue jack he has. It is very simple with the Atwood jack and some others.
โMar-13-2017 11:07 AM
SoundGuy wrote:
snip
โMar-13-2017 04:27 AM
โMar-08-2017 06:35 AM
SoundGuy wrote:
Well I guess we'll never know if the OP was actually able to rotate the head on his tongue jack OR he meant he rotated the entire jack. ๐
Lynnmor wrote:
He said that he tapped two holes at the top of the jack. That might be enough information without adding photos.
โMar-08-2017 05:00 AM
โMar-07-2017 04:13 PM
โMar-05-2017 03:51 AM
Jackfate wrote:
After being told I couldn't rotate the head 90degrees. I did it ,just tapped 2 holes in top of jack tube , turned head 90 and put old bolts in new threaded holes.
SoundGuy wrote:
Perhaps you'll be kind enough to clarify as I suspect you didn't rotate the HEAD 90 degrees but the entire tongue jack by drilling additional holes in the TJ mounting plate - correct? ๐
โMar-03-2017 11:02 AM
โMar-03-2017 09:58 AM
