rear hitch for 5th wheel
ford_coupe
Thinking of putting receiver on my 5 er rear bumber pulling 5x8 utility trailer w/golf cart. is this bumper strong enough for this. 5 er k-z Durango 325? bolt on or weld?
11 REPLIES 11
filrupmark
We put one on our Durango 285rlx2 . Worked great. Also used for one of those rear carriers to haul bicycles, firewood, coolers it was nice. I need to Build one for our new trailer.
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
jasult
I took off the cheap make believe bumper and made this with 3 hitch receiver's
Jim & Georgeanne + Lucie the beagle
"excavator" on the DieselStop.Com
1999 F350 CC LB Hydra chip
1996 F250 Powerstroke, Tony tunes, BTS trans
1995 Fleetwood Wildness 30 ft 5ver
Our Camping Pics and 5ver Album here
Our Gettysburg trip 2010
Williamsburg, Va
okiejoe
You need to check what the total length of combined vehicles for Private vehicles, Too many people read the restrictions for length limits on commercial vehicles and think it pertains to their RV, it doesn't. Where I live legal length is 75 feet but that's for commercial trucks, the legal length limit for private vehicles in my state is 65 feet. I had the restrictions read to me by a state trooper right out of his vehicle code book. He told me people see commercial trucks pulling long loads and think the same laws apply to them but they don't. Ask a Trooper to check for you.
jonrjen
Sometimes you just gotta love the creative minds of others. I wouldn't be too concerned some of the fore mentioned comments. My suggestion would be to check with the manufacture of the RV frame and see if it will support having a hitch attached to it.
Spend some time on a owners forum that is either directly related to the frame manufacture or trailer manufacture to see if others have installed a hitch and what issues if any have come to light.
I would highly recommend that if you do go forward with a hitch that it is a frame mounted and not a bumper mount.
Good Luck with your final decision and direction of travels.
2013 Wildcat 353LS (on of the few out there)
2013 Ford SHO
2013 F350 FX4 CC PSD
Good Sam Roadside Assistance (it's a good thing to have):B
is_it_friday_ye
Find a local welding shop to have them weld the hitch to the frame. I had one done for just a bike rack but he said I could tow pretty much anything I wanted because it was strong.
2007 Dodge Ram 3500 Cummins SRW, Airlift airbags, Bilstein shocks, Smarty Jr., stainless turbo back exhaust, B&W Patriot 18K
2015 Grand Design Momentum 328M, disc brakes, Progressive Industries 50 amp EMS
n7bsn
jasoncw wrote:
cmeade wrote:
Don't forget your CDL with double trailer endorsement, valid medical certificate, controlled substance and alcohol testing, and length restrictions. BTW you can also disable your reverse gear cuz you won't need it while towing.
Wow that's crazy. Glad I don't live in your crazy state. Nothing special needed in MI as long as total length doesn't exceed 75'.
Also not true. CDL==commercial, not recreational.
Calf does require special licensing for double recreational towing and some folk confuse the two.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
ford_coupe
thanks for all the answers very helpful,even the stupid ones. have a great day
jasoncw
2016 Jayco Eagle 324BHTS
2005 Ford Excursion 6.8L 4.56's, V/C Springs, PP 3P, P3
Past:
2011 Keystone Bullet Premier 31BHPR
2009 Forest River Flagstaff 830RBSS
turbopilot51
I had a receiver welded the the frame of my fiver. You do no want to take a chance of something coming loose. Cost more but worth the peace of mind.
cmeade
donn0128
No! Unless you want to tear the sewer hose carrier off one day
