Replaced Tail Lights & Backup Lights with LED's
GACamper
Replaced my stock Tail Lights & Backup Lights with new LED's today.
Sure does look better and a lot brighter then the factory stock lights.
Stop Light/Marker Light/Turn Signal
Backup Light
Both Tail Lights Off
Both Tail Lights On
2013 Montana 3800RE
RV FlexArmor sprayed RV roof..Big Improvement!
A/C, Color TV and a Microwave...Isn't Nature Great?
04.5 Dodge Ram 3500 Cummins 5.9L
14 REPLIES 14
GACamper
gbopp wrote:
They look great. Where did you get them?
We have a Big Truck Chrome Shop here local called Great American Chrome Shop. Here is the link to their web site.
2013 Montana 3800RE
GACamper
ScottG wrote:
Very nice. It's great you could get direct replacements.
It wasn't a "Direct Replacement".
Had to wire in connectors for the lights and had to modify the frame on the Backup lights a little.
These are the same type LED Lights use on semi trailers. The lights are sealed units with a female plug on the back. I went to our local Big Truck Chrome here and looked around and found the lights I like that would work. No issues and works great.
2013 Montana 3800RE
larry_barnhart
I had led light installed on our 2001 alpenlite several years ago. wife said you sure like to waste money so why did you do this? Are they safer she asked and yes was my answer.
checking the lights before we hit the road she saw them come on and said wow that is great.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
larry_barnhart
chevman
chevman
prodigy
scanguage II
TD-EOC
TST tire monitors
FMCA # F479110
Cummins12V98
Well worth the upgrade!
People will actually see your blinkers now and move over!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cobra21
Nice job! I am replacing mine this spring with new LED fixtures as the old ones
don't look overly bright in the daytime.
Brian
4X4Dodger
GlennLever wrote:
I installed LED taillights and had a lot of problems with them burning out, I eventually went back to regular filament bulbs which solved my problems.
LED taillight upgrade which failed
From your photo there seems to be quite a bit of rust, corrosion and oxidation on the bulb holder. This very well could have led to the failure. Some WD-40 and some emery cloth will work wonders on that receptacle.
GlennLever
gbopp
ScottG
TakingThe5th
Big Katuna wrote:
They are safer too. They light up milliseconds faster which equates to following vehicles having more time to stop.
I like the way LEDs come on so quickly-they 'pop' on-helps me notice them quicker, especially in my peripheral vision. Nice job.
TakingThe5th - Chicago, Western Suburbs
'05 Ford F350 Crew 6.0 DRW Bulletproofed. Pullrite Super 5th 18K 2100 hitch.
'13 Keystone Cougar 333MKS, Maxxfan 7500, Progressive EMS-HW50C, Grey Water System.
Big_Katuna
My Kharma ran over my Dogma.
GACamper
tvman44 wrote:
Did you replace just the bulbs or the entire fixture?
The Entire Fixture.
2013 Montana 3800RE
tvman44
Papa Bob
Husky 16K hitch, Tekonsha P3,
