โSep-12-2013 07:47 PM
โOct-02-2013 09:02 PM
xPIXx wrote:1/8 inch slope per 1 foot of travel meets the building code. My Apenlite has about that drop from the kitchen tank to the sewer connect. Mine has a 2 inch dump valve at the galley tank then runs to the sewer connection.
Well I did some measuring and can only get about an 1/8" drop per foot between the two sewer hookups. I guess that's why it wasn't done from the factory. If I really wanted to make it work I think I could by going inside the underbelly and running the pipe out to the other sewer connection, but with that and the pipe running close to the suspension I don't think its worth messing with. I might just get a wye and run a second hose. Maybe I'll just leave it alone and not worry about it.
โOct-01-2013 02:20 PM
old guy wrote:
I have three valves and one is about 6 or 7 feet from the other two. I think I will put a valve from the galley tank closer to the other two so I don't have to crawl under the slide out. I think I will have to drop the under belly and cut the pipe and glue in a valve flange and the rest is history.
โOct-01-2013 07:54 AM
โOct-01-2013 07:26 AM
โOct-01-2013 05:28 AM
INDIAN347 wrote:
I re-plumbed mine and a short section is running up hill !!! Now when that tank is full it pushes right by that up hill.Sure it levees a small amount in line but it worked very good at this time.Now i wish i had came up higher on the rear pipe it would have made a small difference !
โSep-30-2013 08:44 AM
โSep-30-2013 08:17 AM
joshuajim wrote:othertonka wrote:
If you decide to add additional pipe, remember the rules for being a plumber, "Stuff" does not run Uphill and payday is Friday" If you don't have a straight downhill slope to run the pipe with no dips you will have a problem.
...and the third is "Wash you hands before lunch!"
โSep-18-2013 06:55 AM
โSep-17-2013 10:32 PM
โSep-17-2013 02:15 PM
โSep-13-2013 01:45 PM
โSep-13-2013 11:11 AM
xPIXx wrote:ScottG wrote:
The reason they didn't connect the two was pure laziness.
I find that hard to believe. A 16' piece of ABS is cheaper then a sewer connection, laziness would have nothing to do with it.
โSep-13-2013 10:00 AM
โSep-13-2013 09:08 AM
