โSep-13-2014 01:59 PM
Moderator edit to re-size pictures to forum limit of 640px maximum width.
โSep-14-2014 06:01 PM
โSep-14-2014 05:45 PM
Nutinelse2do wrote:
Ok, finished today. Not sure if I am thrilled with it or not. Should be interesting to see how it holds up. Today there were already some of the little strips I used to fill in spots that seemed to be coming up. Time will tell. If it doesn't work, guess I can put up a stainless steel splash.
โSep-14-2014 05:40 PM
โSep-14-2014 04:38 PM
โSep-14-2014 07:43 AM
wmoses wrote:
Well, whaddayaknow ... I was going to finally tackle this upgrade today and I too have such a furring strip (did not know that is what it was called) but in the middle of the wall that I want to install it on. I too wondered what I should do and I was leaning towards butting up against it either side. I might still do that but I thought it was interesting that this thread popped up today. ๐
โSep-14-2014 06:25 AM
โSep-13-2014 06:43 PM
riven1950 wrote:
If you plan on continuing the tiles around the corner I would just remove the furring for a smooth surface. Usually all it does is cover up a seam and you will be doing that. The strips are usually just stapled on so easy to remove. Sometimes you may have to cut along the edge with a knife if it is caulked. I would recommend holding on to the strip you remove. You may need it elsewhere sometime, and matching material is hard to find. Good luck
โSep-13-2014 04:07 PM
โSep-13-2014 03:13 PM
