solar boost
brocun
I did a weekend of boon docking and found that daily I had to run the genny. I am interested in a simple solar panel set up, portable enough that my wife can set it up, to boost the battery and alleviate the need for genny use.
17 REPLIES 17
westend
I would suggest one of those Renogy modules mounted to a lightweight stand and a cheap controller to start. You might consider replacing the battery you're using as it sounds like it has been abused and won't have the greatest service for your style of camping. A good replacement solution would be two Costco or Sam's Club 6V GC2 batteries. The price is close to one good 12V deep cycle battery and the 2 X 6V solution is a proven winner.
Good luck with your solar charging. If done right, there's no more need for a generator.
'03 F-250 4x4 CC
JiminDenver
It use to be that the portables from the fancy outfits were so expensive that you could build your own cheaper. Now it's hard to beat the ones from solarblvd, windynation, eco-worthy, renogy and others.I saw a you tube of someone setting one up and it's pretty easy.
I make my own portables out of the larger higher voltage panels. They are 39x65 and weigh close to 50 pounds, One panel, one run of cables to the controller, around $400 for 16a+ of charging tracking the sun all day.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
pianotuna
Nomad III
Nomad III
You may find the handybob site wordy and it has some information that is dated at best.
Try these sites instead:
http://rvroadtrip.us/library/12v_system.php
http://rvroadtrip.us/library/solar_install.php
Regards, Don
SkiSmuggs
I got the Renogy 100w portable recently, then read some from Handy Bob. Now I would buy the suitcase panels without the charger and buy a better charger separately so I could install close to the battery bank and run longer cables from the panels for more effective charging.
2015 F350 XLT PSD 6.7 Crew Cab, Andersen Ultimate hitch
2012 Cougar High Country 299RKS 5th wheel, Mor/Ryde pinbox, 300w of solar
FINELINE
Most batteries require 14.8 volts (Trojan batteries require) to fully charge your batteries. Most controllers will only get them to 14.4 or 80%full charge. Its not the panels its the preset controllers besides other things like wrong Gauge wire to batteries that waste the volts getting to batteries or charger.
If you are really interested in adding solar there is a lot to read and understand to buy a system that really will do all you need. A lot of cheap and expensive kits are available through dealers and on the net that wont do enough to charge the batteries full.
Buyer be aware. I started reading and learning all you need to install or have installed the right components to get the most out of you money. I asked like you on a site like this and someone sent me this mans address and now I understand it all. He is not selling anything at all, just a great guy trying to help educate us out here through his discovery with solar. link
http://handybobsolar.wordpress.com/the-rv-battery-charging-puzzle-2/
He has written so much about the subject and their is a lot of reading on his site, but like me you will become fully educated on how to live off the grid with 2 panels (320 watts) 2 batteries ( 6 volt) and never run out on power. Don't get ripped off by dealers selling you short on what you need. Be an educated buyer.
mrw8i
We are very conservative in our power usage when boon docking (almost all of the time). LED lights, parasitic usage, sometimes plug in the laptop, maybe nightly heater usage (about 3.5A draw). About 200AH of battery. Need to charge every few days. 17' TT. Got tired of carrying around a generator so added 200W of solar - during high charge time around noon in the summer it's about 9A of charging.
Solar has no problem recharging normal loads by about 2PM the next afternoon without using a generator. If I go to an area that might have a lot of shade, and am there for more than 3 days, I still drag along the generator.
Now to add solar to our new to us 35' Toy Hauler. Even though it has a built-in generator, want to charge while we are away from the trailer during the day without running the generator.
RoyB
I am always amazed at the SUCCESS stories about using solar panels...
I guess the way to success is to never get behind the charge curve on your battery bank. The solar panels then become a top-off source of charge energy for the battery bank when in high sun.
My daily schedule routine with all the 120VAC items using an Inverter and 12VDC items direct connected seems to draw around 22 AMPS (appx 300WATS) on my battery monitor meter 300WATTS between the 6PM and 11PM . This includes my parasitic drains. This equates to about 134AHs of battery drain over the one day/night run off the battery bank. This will drain down my 255AHs to its 50% charge state by 8AM the next morning. My trailer is equipped with LED lights and has smart mode charging capability for the batteries.
In my case having a single 120WATT Solar Panel or even two 120WATTS Solar Panels would get behind the battery charge curve real quick.
The 120WATT Panels will only provide 14.4VDC @ around 5AMPS each of DC Current in the high sun. The average time of high sun is around 6 hours and will only give you around 30Ahs of usable charge current per panel. Adding two of these bumps that up to 60AHs... Three panels makes it to around 90AHs. I am still behind the battery charge curve of not being able to put back into my batteries verses what I am taking out if I am using 132AHs a day.
When I get behind the charge curve I have to use my 2kW Generator to do the initial start-up BOOST Charging for around one hour using smart mode charging from my on-board converter/charger being run by my 2KW Generator. My 255AH battery banks initially jumps to around 52-53 AMPS Current demand from my converter/charger and this will slowly drop back to around 8amps of DC Current in about an hour run time as the battery banks starts taking on charge.
Once it gets past the high current demand then I can really use the solar panels to continue the battery bank re-charge to get to the 90% charge state or higher while still in high sun.
It all depends on how one likes to camp off the power grid and use the appliances and lights etc that they want to use. I must start out each day/night run with a good 90% charge state on my battery bank otherwise it goes dark on me around 10-11PM at night.
If I was just running LED lights and a occasional short term higher current draw then YES I can see where I would not get behind the battery charge curve and not have to re-charge in a few days... This just doesn't happen for us the way we camp with all of our toys... Ham Radio guys have to yak on the Radios too as well...
We basically look just like we do at a regular camp ground electric site with the exception of using the air conditioner and high wattage microwave. Just about everything else is up and running... When it gets cold at night this is an another story if the furnace has to run...
We have been very successful camping off the power grid with our 255AH battery bank and recharging each morning using our 2KW generator starting at 8AM when allowed to run it. Just now starting to think about adding solar panels to my POPUP trailer only to supplement the generator run times and hopefully reduce the amount of time I have to run my generator.
just my thoughts based on how we camp off the power grid and using solar panels to supplement the generator run times...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
brocun
Fishbreath, was your unit home made or is there a brand name associated to it?
Fishbreath
Brocun
I had a 185 watt panel that was on a portable stand. I ran a 50 foot cord from it to a controller and then into the batteries. I would move the panel a couple of times a day to keep it pointed at the sun. With 2 group 31 batteries I was able to dry camp for 10 days at a time without using the generator. I did have LED lights and was careful with electrical usage, but I also ran a CPAP at night. It can be done!
Good luck
Bill
Community Alumni
Not applicable
I have a 120W portable kit that is almost identical to the Go Power kit shown in a previous post, but the cost was just under $200 from Solar Blvd.
The portable kit works very well, it's easy to handle and it can be stored practically anywhere. Not only do I use the panels for dry camping, I keep the portable kit connected to the TT batteries while in storage to keep the batteries fully charged.
I highly recommend the kit from Solar Blvd. You can't go wrong with the price.
brocun
thank you for the speedy responses. I truly appreciate it.
PFitt
I'm with you on not running gen. just bought Zamp 200 watt portable set up. installed 2nd group 31 batt. 600 watt inverter to run my Cpap at night. Led bulbs throughout camper going to Glacier National Park for 12 days no power inside park!! will let you know how it works out.
http://www.solardealz.com/Zamp-Solar-200-Watt-Portable-Solar-p/zs-200p.htm
http://www.m4products.com/1156-24-5050-cw-1141-cool-white-5050-smd-light-bulb-with-round-base/
http://www.m4products.com/1156-hp-5wcree-cw-cool-white-skinny-cree-reading-lamp-bright-5w-ba15s-base/
mrkoje
I just bought one of these to supplement my still non-existent rooftop solar panels. Actually I fib, the trailer does have a very generous 20w panel (useless) on the roof. In the future I want to add some of the flex panels to the roof. Right now this is really what I got and it does a good job keeping the batteries topped off. Keep in mind though I don't really use a lot of power during the day except for the radio. I also do not have an inverter ... yet.
By the way - you can't get any simpler than this. The solar controller is mounted to the panel. All you need to do is attach the cable to the battery and then set what kind of battery you have on the controller. Thats it - when you need to pull the solar kit out all you need to do is unfold it and then hook the connectors together.
Go Power 120W portable solar setup
I found out about this setup from this couple full timing. They make some pretty good vids as well.
Gone with the Wynns - portable solar setup
RAPTOR 300MP
RAM 3500 MEGA CTD 4X4
bcsslc
I was in the same boat. Getting tired of running the genny and everything else that goes with it. So about three weeks ago I set up my solar system. The last two trips out we were out for four nights and never ran the genny. It was a great feeling.
I honestly don't have an exact $ amount on what I spent on the parts but think it was around $600.00 . I installed everything myself. It took a full day with some breaks because of the high temps. That said I have had my 128 flex panel for abiut one year and have spent many sleepless night figuring out ever step of the install before game day.
There is a great video on YouTube that was made by a member on this form. I believe the YouTube channel is R.V.ing with tito. Or search for "flexable solar panels rv" and it should pull up.
Super helpful video and lots of tip. Although definitely do your own research. It wasn't till I started my install that it all started to make sense. I knew I had the right parts but it was how they really worked is what came together for me.
So to sum up what I did....
128 uniflex solar panel (I have sense purchased another that I will install next cloudy day)
30 ' of recommend cable
mppt controller with a wired remote that is mounted next to other switches
15' of red 8 braided wire
15' of black 8 braided wire
several feet of flex conduit
several feet of 3/4 pvc
One elb exterior junction box
several tubes of dicor roof sealant
Amazon is a great resource for most of the materials needed.
