Sep-24-2015 05:11 PM
Sep-28-2015 05:55 AM
Sep-27-2015 06:45 AM
westend wrote:terryaGJ wrote:
I might have to rethink this.
An alternative might be to mount them on the sides. There is a member on the Forums, Tom from New Hope, that his modules on the sides. He has a hinge apparatus that allows the modules to be flat or at any angle. A strut is used to prop them up, IIRC. The hinge pins are removable so they can be deployed onto the ground, if necessary.
If it was me and I couldn't find the roof truss under the plywood (I can and did), I'd use a molly bolt just slightly smaller than the bracket hole and through drill the roof, insert bolt, tighten, and they are fastened. Cover the bracket with your sealant of choice.
FWIW, I installed my mounting brackets through a layer of Eternabond tape. This 45 second Video at Eternabond convinced me.
Sep-27-2015 06:33 AM
Sep-26-2015 07:09 PM
Sep-26-2015 06:31 PM
Sep-26-2015 11:31 AM
Sep-26-2015 05:20 AM
Sep-26-2015 05:05 AM
Sep-25-2015 08:24 AM
Sep-25-2015 03:26 AM
Golden_HVAC wrote:rickthescot wrote:
Sounds like a great idea. I guess asking for pictures again is not going to persuade you though. We are visual creatures and I don't think 1000 words will accomplish what one image will. You can do it, just one pic.
More pictures that I took a few days ago to post pictures of my solar panels, and their mounts. Some pictures are really close up pictures of the solar panel mounts, and give a clear picture of howrough the surface is.Golden_HVAC wrote:
Hi,
This is my front pair of panels. 120 watt mounted on a curved roof, 102" wide.
This is the mount it is held on with three rivets into the frame, and then the bottom half is 6" long aluminum, with nutsert in the upper piece, bolt you can not see from the outside edge pointing inward.
This picture shows the bigfoot panel mount sold by RvSolarElectric for $35 a set back in 1994. I wonder what they cost today?
This picture shows the panels tilted while I was working on the roof.
Fred.
Porsche or Country Coach!
Sep-24-2015 09:17 PM
Sep-24-2015 08:36 PM
