Stove light upgrade
YamaDooed
Replaced stock craptastic stove light with LEDs simple add on for $20...
Dealer said no way to make it brighter... Ok...
Moderator edit to re-size pictures to forum limit of 640px maximum width.
10 REPLIES 10
YamaDooed
To answer the question simply its only been in service one complete season of stove top and oven use... I know our use is simple baking biscuits and frying bacon mostly... I did this mod in the spring this year and noticed no cracking or heat checking in the acrylic lens covers... Hengs oem lens cover is plastic and also the filter retainer are located closer to the stove top heat source...
Answer#1 not a silly ? but yes most RV lighting and fans are 12v...
Nunyadamn
Do you see having any problems with the lights melting from the heat of the cook top? That would be my only concern. I don't know if the original light that comes with these hoods are anything special like high heat resistant. I like the mod and will be copying.
2014 Jayco Jayflight 32BHDS
2015 Ford F250 Lariat 4x4 Crew Cab 6.7L Powerstroke
riven1950
Dumb question I guess, but are the fan and lights on the Range Hood 12 Volt?
BurbMan
Nice mod, thanks for posting!
Bucky_Badger
nice, but I like the dim crappy one that it came with...makes a good night light
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
Blacklane
Nicely done, and a useful mod.
YamaDooed
Wiring is all from original switch from stove I believe one screw needs to be removed from stove to gain access to wires and drill two holes for wires... LEDs are from walmart boating section installed with self tapping screws into top of hood being carefull that the screws land in void in cabinet... Less than thirty min install and crisp white light...
riven1950
That is what we need. Where did you get the lights. Wired in from the original lamp wire? Looks nice!!
coolbreeze01
I like it.
2014 Sandsport 26FBSL
K_Charles
When anyone says "no way" they may not know much.
