Tired of carpet in bedroom want wood floor
Thunder_Mountai
After 7 years of pretty hard use including about 3 months a year the last four years, the carpet in the bedroom looks really bad. Hate the think how many thousand square feet of wood floor we've put down in the last three houses. So, we have the knowledge and tools to do the work.
We put a laminate floor in the living area of a fiver which required floating and putting down quarter round. The bedroom area has too many ups, downs and arounds to put down quarter round and keep my sanity. Can't use solid wood flooring because of clearance issues with the slides.
Anybody got some suggestions including brands of non floating flooring that is thinner than solid wood?
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2020 Keystone Outback 327CG
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
10 REPLIES 10
Thunder_Mountai
OP here... Looked at a friend's '06 Diplomat which is very close to our unit. He had put Allure down in the living area and entrance a couple years ago. He is a house builder and has made many modifications to his MH. He put the Allure down using silicon between it and the OSB flooring so that it would give while moving and allow the floor to expand and contract. MH has a couple of years of use on the flooring and thousands of miles with temps ranging from below 0 to 100+. Still looked really good. Since I'm using it in the bedroom which is a lower traffic area, Allure should work for me.
2018 Rubicon
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
RVUSA
Unfortunately I dont remember the brand. I bought it at carpeteria in goleta. ca when we were over by there a few years ago. I looked on their website and didnt see any hickory that looked like what I bought at the time. It was around 9/16" and the finish was warranted for 25 years.
Thunder_Mountai
RVUSA wrote:
vinyl in an 07 40' Endeavor? LOL no please dont do that, honor the rig and put an engineered flooring down. I put an engineered Hickory down in a 38'r and it's still amazing looking.
What brand of engineered floor did you use?
2018 Rubicon
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
RVUSA
spoon059
donn0128 wrote:
Allure vinyl plank flooring has gotten a lot of RV use. Easy to lay down, only takes about 1/4 inch, many many colors and looks good down.
X2. Your best bet for durability, ease of install, ease of cleanup, price and light weight will be vinyl. Vinyl technology has come a long way recently and you can get very high quality looking vinyl with texture now. Go to Home Depot/Lowes and look at what they have to offer.
I got a little over a thousand square feet of vinyl flooring (4" wide planks by 3 feet long) and installed that in my concrete underground basement this past summer. Came out great and cost 75 cents a square foot. You can't beat that with a stick!
2015 Ram CTD
2015 Jayco 29QBS
westend
I think you'll find that most nail-down strip or plank flooring is 3/4" or 11/16". Glue-down can have a smaller dimension like this engineered product which is 3/8". I would shy away from either of these as a solution for an RV as the subfloor has too much movement. IMO, you're better off with a floating floor and bite the bullet with trim. It doesn't have to be 1/4 round covering the expansion space, you can use a straight piece or even caulk the gap if cutting trim is beyond your endurance.
'03 F-250 4x4 CC
WoodGlue
You might also look into BeauFlor brand.
They're a little more expensive but worth it!
WoodGlue
2002 Land Rover Discovery II
2014 Lance 1685 - Loaded - 4 Seasons - Solar - 2 AGM's
When Hell Freezes Over - I'll Camp There Too!
Lance Travel Trailer Info - Lance 1685 Travel Trailer - Lance 1575 Trailer
donn0128
Road_Runners
For boats you could purchase plywood flooring (8X4 sheets) that had a veneer of teak and holly. I would suspect that you could buy other such sheets of flooring
'05' F-250 Power Stroke
'00' 30' Cameo Fifth Wheel
angler
How about something like a cork tile?
2020 Jayco 34RSBS
2002 Tiffin Allego Bay
2010 Keystone Springdale 29bhssr
1998 Jayco Lite 244
