Trick for monitoring freezer while absent:
Gypsy62
2 week biz trip + freezer full of tri-tip + thaw/re-freeze paranoia =
A. Place plastic cup of water in freezer until frozen.
B. Place a few coins on top of the frozen water.
C. On return, if coins not at bottom of cup, no thaw/re-freeze event.
Back onsite, I was confidently content to flip a few dry coins before flipping a few steaks.
PS- never try to change the text size of your post using the below-right tab; it auto-erases all existing text.
Arrgh.
4 REPLIES 4
Chuck_thehammer
coins or ice cubes work well.
or a small battery powered thermometer.. with memory..
used to be mechanical thermometer.. with tabs.. if going over 40 degrees.. tabs keep pointer at 40.
Gypsy62
If you have them, cubes idea great alternative!
mrquacker
Another idea: Place a couple ice cubes in a glass, and place in freezer. If you only have one BIG ice disc, then you've gone through the thaw/freeze cycle.
gbopp
So, what if two coins are on the bottom and one is still on top? ๐Ÿ™‚
