Feb-27-2016 02:45 AM
Feb-28-2016 06:49 AM
icanon wrote:
If it's in a sealed box with out going vent then you need a in coming vent. That said, rewiring to converter is required but not that difficult, also, power coming from TV for recharge can be affected due to longer distance. And make sure you have 12v supply to break away switch for TT brakes.
Feb-28-2016 06:37 AM
Feb-28-2016 04:54 AM
Greywolf26dbh wrote:
I am looking to upgrade my battery to two golf cart's. However, I can't handle the additional tongue weight ...
SoundGuy wrote:
Really?
If increasing your trailer's gross tongue weight by a mere 50 lbs puts you well over whatever rating it is you're concerned about that suggests you have bigger issues that just gross tongue weight.
JaxDad wrote:
Sounds like a project to make a very simple thing into a huge hassle to me too.
Feb-28-2016 04:20 AM
Really?
Feb-27-2016 05:15 PM
wanderingbob wrote:
KEEP IT SIMPLE . Fifty pounds will make very little difference . Put a couple cases of beer behind the axles and it will be OK!
Feb-27-2016 03:55 PM
Feb-27-2016 03:51 PM
Greywolf26dbh wrote:I have my intake on the inside of the trailer. You can draw air from anywhere as long as you aren't introducing any bad gases back in like exhaust gas from appliances. I located the intake on the opposite side of the battery box from the outflow.
So are you saying the lower air intake vent is to the inside of the trailer or to the outside as the exhaust vent?
Feb-27-2016 01:53 PM
Feb-27-2016 11:06 AM
Feb-27-2016 09:48 AM
Feb-27-2016 09:19 AM
Feb-27-2016 04:17 AM
Feb-27-2016 03:49 AM
Feb-27-2016 03:25 AM
