Under bed storage
out_for_a_rip
Hi Everyone - Our new TT under bed storage did not come with struts to support the bed when opened. Does anyone have any alternate suggestions for keeping the area open? I am thinking maybe a board on a hinge that folds open to a block attached to the frame but before moving forward I thought I would ask the group.
Thanks!
18 REPLIES 18
1L243
Another route you may consider, After adding memory foam mattress topper bed is so heavy and right up against the wall between the bedroom and livingroom I gave up on the bed lift and added slide out drawers. I got the idea from a guy on another forum who has a similar trailer.
by removing the side paneling and using it for drawer fronts and using 5/8" double laminated plywood that I found at a building recycle center for $4 per 4x4 sheet. I used bottom mount 100lb drawer slides (would recommend under mount) but I could not find them in my town.
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
doxiemom11
I wouldn't be able to lift our bed without the struts. Our storage area is under the entire queen bed. So, it is very heavy with mattress, memory foam topper and bedding.
AllegroD
Get the struts and reduce the amount of bend and lift.
nineoaks2004
I cut a piece of 3/4 PVC water pipe and notched it so it would not slip, works ok for me..
By the time you learn the rules of life
You're to old to play the game
old_guy
on one of my older trailer I once had I used a folding rv table kitchen leg and it worked great. they lock into place so the bed will not fall on you
Almot
Why re-inventing the wheel? There are struts made exactly for this purpose: Hatchlift RV Bed struts. Make sure you get the right strength for your bed, see the chart. If bed is MUCH heavier than the struts rating, it will try to close slowly but you'll be able to hold it easily. If bed is MUCH lighter, it will try to lift when you're not in the bed, so you might have to add some hook. Those are extreme cases, struts rating has pretty wide margins.
Those 4x4 plywood pieces are bases to mount the brackets on the wall, but RV underbed storage often has thin 1/8 plywood walls, you might want to put a longer piece of board resting on the frame.
Ltrip
We just took delivery of an Arctic Fox 25Y and am surprised how well the struts work. In my previous 5th wheel, the struts made it a bit easier to lift the bed, but would not hold it there. On the AF 25Y, the struts exert good pressure on the upward motion such that with the mattress off, the lid springs open. It is very easy to open with the mattress on and stays up, requiring a bit of a push to get it back down. I am VERY pleased with how well they work!!!
Larie Trippet Reno/Tahoe region
2018 Ford F250 Lariat Ultimate CC SB 4X4 diesel
2018 Arctic Fox 25Y
2019 BMW R1250RT
SoundGuy
Etstorm wrote:
Actually, I use an old putter as a prop. The flat sole rest on the floor inside the storage area and the rubbber grip keeps the lid in place
Way too hi tech for me. :W
2012 Silverado 1500 Crew Cab
Etstorm
pianotuna
Nomad III
Nomad III
I hate my struts. I will replace with a drop down leg similar to the ones dinette tables used to have.
Regards, Don
ktmrfs
I tossed the struts in ours. the strut mounting often was interferring with items placed near the edges when closing. So, to make it less troublesome I took them off. Then I just cut a piece of 1x2 the length I wanted to prop against the bottom and top that I put in place to hold the top up.
2011 Keystone Outback 295RE
Terryallan
the struts are not expensive. You will prolly need to brace the bed box. Most RV dealers have them
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
out_for_a_rip
Great idea with the cabinet doors, I just installed some underneath our dinette. I am going to take some measurements tonight to see if I could do something similar.
Trailer manufacturers change interior decor on a regular basis so if yours is a new trailer the trick is to look around your own model or others in the same lineup to see if there's a cabinet door of the dimensions you require. Once you do find one order a couple from your dealer as replacement parts, along with the matching hardware - that way the installation will look completely stock, as if it was done at the factory. ๐Ÿ™‚
That is exactly what I did for underneath my dinette, but I went through the manufacturer instead of the dealer. I was really surprised at the reasonable price from the manufacturer.
SoundGuy
