USB 120 volt outlet
Bob_Vaughn
Has any one replaced one of their 120 volt outlets with a usb 120 volt outlet? If so did you just go to lowes/home depot and get one there ? If so was there any issues replacing the one in the rv?
27 REPLIES 27
tenbear
Here is a youtube video on how one person installed a 120v/usb combo. Replacing a 120v outlet is basically the same.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
4x4van
I just installed this in my MH.
Nice & easy; just tap into a 12v source, 12VDC is always on/available. I recommend putting it inside a cabinet, since the blue power LED is fairly bright (or you could run an inline rocker switch to turn it on/off).
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
Harvey51
I bought two in a package at Costco. I installed one in our house. Quite a job due to the very large size of the thing, just barely fitting into the electrical outlet box. Connection screw for only one black, one white and one safety ground wire, so Marettes and pigtails were required to hook it up in the middle of a multi outlet run, leaving barely enough depth for the big outlet. I doubt if I will install the second one - certainly not in the RV. Green LED stays on all the time.
They say a GFCI uses $3 of electricity a year. I bet this thing does as well. It adds up, especially if you have a couple of arc interrupter breakers using $5 a year as well.
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
Thunder_Mountai
westend wrote:
n7bsn wrote:
A replacement style USB/Outlet link
Yup. that's a nice one. Just a word, though, that a residential receptacle will need to be mounted in a box. Many RV's are wired without gang boxes.
That is the one I installed in my MH. Had to do some cutting to add a box. Nice addition. Did away with some clutter and preserved the outlets.
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2020 Keystone Outback 327CG
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
beemerphile1
ICamel wrote:
Found this neat little wall plate adapter at Wally World yesterday. Only downside is that one USB port is listed as for Apple "I" products and the other listed for Android products.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=en&scy=us&ctn=SPP3038A/17
Apple products like a 2 amp charge whereas Androids charge at 1 amp, however they both are 5 volts.
An Apple product will still charge at 1 amp but will charge slower. The Android can also charge from either except the phone battery may get hot on 2 amps.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
ICamel
ICamel
2017 Arctic Fox 992
2005 Ford F350 Lariat SuperDuty CrewCab 4x4 + 6 Speed Manual + 19.5" Tires + LoadLifter 5000 Rear Air Bags
2005 16' River Wild Drift Boat
Honda EU2000i
Trophytrout FlyFisherman
AH64ID
I installed one of these where my tv plug was.
USB Outlet
I moved the TV outlet to behind the stereo, never understood why TV power/cable had to be exposed, and then put the usb/120 plug in.
That plug will shut off the output when the device is charged, and has an indicator light. So far it's been a worthy upgrade.
-John
2018 Ram 3500-SRW-4x4-Laramie-CCLB-Aisin-Auto Level-5th Wheel Prep-Titan 55 gal tank-B&W RVK3600
2011 Outdoors RV Wind River 275SBS-some minor mods
beemerphile1
Bob Vaughn wrote:
I picked up the receptacle yesterday and after removing the receptacle from the rv wall I swapped the mounting tabs from the rv one to the new one and it worked just fine.
I don't know what mounting tabs you mean but I will reiterate what others have said.
When replacing an RV/mobile home receptacle with a residential/commercial receptacle, the new one must be in an electrical box. This is a safety code requirement.
Bob_Vaughn
I picked up the receptacle yesterday and after removing the receptacle from the rv wall I swapped the mounting tabs from the rv one to the new one and it worked just fine......
beemerphile1
I prefer to plug an adapter into a 12vdc receptacle. I always have 12vdc but only sometimes have 120vac.
GordonThree
christopherglenn wrote:
That one has 2 "apple" ports and 2 " not apple" ports. your guess is as good as mine as to the difference.
I ended up getting a pile of these for the TV and cars... 2.1 amps per port, 3 ports, plug anything anywhere.
The difference is how the data pins are loaded (resistance). Some Apple and Android devices look at the loading on the data pins to determine how much amperage the charger can supply (or if it's even compatible)
ronfisherman
Moderator
Moderator
I installed a couple of these Surge protector/120 volt/USB adapters. They also make them with front 120 volt plugs.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
Golden_HVAC
I have a cell phone that says "Unplug adapter to save energy". If you have a wall mounted USB port, then you will have no way to unplug it without shutting off the circuit breaker, or in the case of a switched receptacle, then shut off the switch to keep the USB plug from drawing power all night - when not in use.
A better way is to just have several USB adapters. Then plug that in when you want to charge or run something with a USB port. Unplug when not needed.
With a RV, have you ever removed one of the receptacles? Most are not like a house, with a separate box and receptacle with wire connections inside the box, with a separate cover. Rv's typically use a RV style that is all in one, that does not have a separate box or cover. So I can not see a "Typical" home receptacle ever fitting in the RV opening (that normally will not have a box to contain the electrical power).
I have installed a new box and new receptacle in a RV, with a cover. It takes about 4-5 minutes to install one, compared to about 45 seconds for a RV style receptacle.
Good luck!
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a
Porsche or Country Coach!
I havn't been everywhere, but it's on my list.
Kangen.com Alkaline water
Escapees.com
christopherglen
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
