โAug-21-2013 10:07 PM
โOct-19-2013 11:26 AM
My 1141 stock trailer bulbs are 18.4 watts and from what I've read, suppose to be approximately 260 lumen. My 1141 TH bulbs put out much much more light than these 24-5050 panels. The 24-5050 should put out over 360 lumen. Either the led ratings are way off, or all led smd 24-5050 panels are not created equally at all, huge difference.
โOct-19-2013 03:10 AM
โOct-18-2013 02:46 PM
โOct-14-2013 12:12 PM
DAWg134 wrote:
"Is this a 24 5050 panel, or did they send me something else...?"
AllCool,
The spec sheet I found for white 5050 LEDs (http://www.wayjun.com/Datasheet/Led/5050%20SMD%20LED.pdf) shows between 14-16 lumens per LED, so 24 ought to yield roughly 360 lumens. The luminous efficacy of a typical incandescent bulb is 16 lumens per watt, so 360 lumens would only be equivalent to a 25W bulb... not particularly bright and considerably less than many of the flashlights I have stashed around the house.
I'm guessing you got what you paid for.
โOct-14-2013 12:10 PM
westend wrote:
I would think that .07 is within design standards and it's questionable if that caliper and the measuring points wouldn't have some error (I own the same caliper).
โOct-13-2013 09:18 PM
โOct-13-2013 10:37 AM
โOct-13-2013 07:10 AM
โSep-28-2013 04:08 PM
โSep-25-2013 04:34 AM
โSep-24-2013 06:53 PM
โSep-24-2013 05:50 PM
rkentzel wrote:
These people are less than honest in there dealings. They sent me the wrong product and they know it and dont care. They went in and removed the picture from the order conformation and made it blank they could not change the description. I am currently in a dispute with pay pal and CC company.
Like usual I'm a day late. Just ordered from them yesterday. Did a search here tonight to see the different ways people secured them in the fixtures, then came upon this thread...
I ordered ten, 24-5050 panels, pure white for under $19. Suppose to get them by oct10. Time will tell how this seller treats me. I'll post back my results.
jmo
โSep-07-2013 02:32 PM
โAug-23-2013 09:20 AM
