โJan-20-2014 04:52 PM
โJun-04-2014 05:19 PM
โFeb-06-2014 09:48 AM
JBarca wrote:
Curious to know if you ever find out what it is.
โFeb-06-2014 08:25 AM
โFeb-06-2014 06:00 AM
โFeb-05-2014 03:36 PM
โFeb-05-2014 12:01 PM
โFeb-04-2014 06:52 PM
Trlrboy wrote:
Take a look at my signature photolink and you will see an album of my water filter install. Took about an hour. First filter is 1 micron and the 2nd one is a carbon block. Zero taste at all, zero smell. Great products from the RV water filter store.
โFeb-04-2014 06:45 PM
myredracer wrote:
It's interesting that the deposits are only on the 2nd strainer. Perhaps the screens are different metal? No odor but then it's been a few months now. I wonder if it's iron bacteria or something that feeds on iron? If it is iron bacteria, it's not a health risk at least. I wonder if it can be analyzed at a water testing lab?
Iron bacteria
That article on Legionnaires disease is definitely interesting and food for thought. It sounds like what you are saying is that it would be prudent for RV-ers in hotter areas of the US to regularly treat their holding tanks. When reading up on it a bit I learned that the Legionella bacteria is naturally occuring in some lakes and rivers and apparently even in potting soil. So I guess some folks *could* end up with the bacteria in their holding tanks and all you need is the right conditions for it too flourish?
โFeb-04-2014 10:30 AM
โFeb-02-2014 07:41 PM
JBarca wrote:
That said, were you camping in an area that was high in iron? This is total speculation but there may be โsomethingโ stuck to the screen and then a high iron source came through and attached to the stuck something. Does it smell like iron or foul something? This one I do not know. I would for sure do a good sanitize of the camper come spring when you start using it again.
John
โFeb-02-2014 06:38 PM
myredracer wrote:
I had no idea what the effect of a carbon block filter can be from chlorine reduction on the downstream water. I am going to go back to the drawing board on the "whole house" filter I bought, a Pentek Floplus-10. I chose it because it's 0.5 microns, is designed for a high flow rate and it combines carbon, sediment and micro-organism filtering all in one. While it does have a polypropylene media, it does not have KDF or silver in it. I just looked at the fine print that I didn't see before and it says "Warning: For drinking water applications, do not use with water that is microbiologically unsafe or of unknown quality without adequate disinfection before or after the system." It sounds like if you are not using water from a treated municipal system and the water quality is unknown, this filter is not a good choice.
I grew up on chlorinated city water. After being on well water for 20+ years, when we go anywhere that has chlorine in the water, it seems almost overpowering at first. We don't find it offensive enough though to make a carbon filter a must. It seems like the carbon particles aren't just there for the chlorine though.Yes, you are correct, the carbon takes out things other than chlorine.
I still want a decent flow rate filter with a lower micron rating and with KDF or silver to prevent bacterial growth. I was looking at a 10" Pentek whole house filter that has KDF in it but it is 4.5" in dia. and retails for $80, so that's not an option. Perhaps two filters would be a good choice - a main whole house one and a separate one under the kitchen sink just for drinking water? I drink a lot of water straight out of the tap. In reading your links on KDF and Silver, it seems like KDF would be a good choice. I don't know what that does to cost or dimensions.Yes, KDF is the newer method. When I have broken the top off of one of ceramic carbon filters I can see the KDF mixed in with the granulated carbon. It looks like the granulated KDF right off the KDF web site I linked you too. From my background, I would recommend the KDF or silver when using a carbon filter.
Here is a photo of the strainer out of the water inlet fitting on the exterior of our TT. This is how it looked 2 months after winterizing at the end of the season. It looks to be about 50% or more covered in something. Interestingly, the strainer at the end of the hose at the CG faucet is perfectly clear. I always check the one at the faucet end but never thought to look at the one on the inlet. I have no idea what the material on the strainer could be. Algae? I don't exactly relish the thought of ingesting the stuff whatever it is. Could the stuff also be somewhere in the water dist. system inside our TT?
Related to this thread, I came across the below article recently on Legionnaires disease in RVs. When I looked into to it, it seemed highly improbable that this would be a concern in RV systems because it normally occurs in highly complex water systems such as in large buildings; in systems with lime scale, sludge & rust buildup; and in holding tanks where there are elevated temps (68F and higher) for long periods. And then you need to inhale the infected water, not drink it. Not really conditions present in an RV.
The article cites a case of an RV-er that contracted the disease but was already in a higher risk category to start with and it doesn't include any evidence on exactly how and where he might have contracted it. If it was a problem in RVs, I have to think you'd hear a lot more about it. In reading through the article, it doesn't seem particularly credible the way it was written.
3.2.2. Demographics
All of the RVs in the study were registered in southern states including: TX, GA, FL, SC, VA, and NC except for one registered in the state of OH. The four RVs culture-positive for Legionellae were registered in different states, GA, SC, TX, and TN (Table 1). The average model year of all the RVs included in the study was 1997 and the average model year of all of the four positive RVs was also 1997. No specific make or model was associated with a positive Legionella culture.
3.2.3. Maintenance
Fifty percent of all the RVs surveyed had RV general maintenance performed within the last year with 60% of RVs having the water tank cleaned within the last year. Only one reported cleaning the water tank with chlorine. Others reported draining and or flushing as the cleaning procedure.
Forty-five percent of all the RVs would have the water tank drained when the RV was put in storage. However, only one of the RV owners treated the RV tank with chlorine before putting the water tank back into use.
2. Case Report
A 50-year-old previously healthy man who smoked occasionally and drank moderately attended an antique car exhibition in rural Pennsylvania in the fall of 1993 with several other enthusiast friends. The group traveled by RV and lived in the vehicle for several days using water for drinking and bathing directly from the storage tank. The water supply was replenished when required by refilling the tank with local tap water from a municipal system.
โFeb-02-2014 10:55 AM
JBarca wrote:
Red,
Here is what I know. If we happen to have a RV'er who is a water treatment person or a microbiologist they may add some more.
Hope this helps
John
โFeb-01-2014 07:38 PM
myredracer wrote:
Jbarca, what's the story on filters that have silver or an anti-microbial agent in them to help kill bacteria and organisims? Is it correct that some filter media are more resistant to bacteria growth? I think I read that polypropylene is better in that respect and that paper is not good?
Should an RV filter be tossed out once a year regardless even if it's had low use?
โFeb-01-2014 06:40 PM
myredracer wrote:
JBarca,
More good info. Seems like all of your info. would be good for a sticky...
Apologies for asking more questions... ๐
1. What does a carbon block filter do to chlorine in your water after the filter? If I install a carbon block filter that filters the entire TT, is that possibly detrimental? It seems like some RV-ers use a carbon block filter. In our case, the water inlet is right below the kitchen sink (only a few feet of pipe) while the bathroom sink is 10'+ away but the only time you'd ingest water in the bathroom is a small amount when brushing your teeth.
2. I noticed at the end of the last camping season (51 nights), that the little screen filters on the hose and water inlet were plugged up with some kind of crud. Not sure if it is sediment and/or algae. Any idea what it is and what the negatives are? Would it originate from a public system or private well system?
3. Just how good is bulk filtered water that you buy at stores or bottled water compared to city water that you'd use at a CG? I seem to recall reading that it's not as good as they make it out to be. We get bulk water in 5 gal. bottles for DW as that's all she will drink. The bulk water comes out of the filling machine pretty quickly so I am guessing the level of filtration isn't that great? I'm pretty sure they are supplied by city water.
I've been drinking well water for about 20 years at home. One was 300' deep or so and artesian. Our current well is a recently built shallow one (30'). When you build a new house here in Canada that has a well, your municipality requires you to meet "Guidelines for Canadian Drinking Water Quality". Link below. I think some provinces have their own regs. for public and semi-public water distribution systems. For private homes at least, they don't require any on-going testing. If you construct or drill a new well, there's no testing requirements which seems odd.
