โMay-19-2014 04:25 PM
โJun-04-2014 02:24 PM
โJun-03-2014 03:10 PM
Steakman wrote:
2 Trojan T-105 Will give you at least 420 Amp Hours.
โJun-03-2014 08:43 AM
Steakman wrote:
FORGET About "RV-Marine Batteries". That term is the biggest bit of misleading BS I have ever heard. SCAM talk.
They are NOT in any way shape or form a Deep Cycle battery.
Best advice in thie thread is going with 2 6V and reading the Battery FAQ that another memeber put up.
Plenty of power for pretty much any RV and if you add a 120 or larger solar set up..you really wont have to worry aobut losing power..depending up on load of course. Its what I have run for the past number of years although this year I added an 80 to my origianl 80 watt panel...now I find in bright Sun the solar charges at a higher amp rating than plugged into shore power.
Take your time before you buy..read the FAQ..worth it...at least I thought so 8 years ago when i saw it posted here.
rgdfs,
Stk
โJun-03-2014 06:14 AM
โJun-02-2014 04:16 PM
โJun-02-2014 11:43 AM
โMay-28-2014 05:01 PM
'06 GMC DMax CCSB 594,545 km
(368,890 miles)
2003 Citation 26RKS
.โMay-28-2014 01:57 PM
โMay-21-2014 12:45 PM
kamperdog wrote:I'm using them and their health seems good after a long winter. The other thing about 6V GC2 batteries is that they are forgiving. I see a lot of posts on here about 12V batteries only living a short time and I would bet that is because they are drawn down too far for a few times and the thin plates of the battery doesn't recover fully. 6v batteries are more forgiving should this happen.
I see Sams' club has Energizer 6v golf cart batteries. Yay, nay? Any particular brand thats good or to stay away from?
โMay-21-2014 08:08 AM
โMay-20-2014 11:48 AM
kamperdog wrote:
Piano tuna... thanks for that link! Quite interesting! As far as the extra posts he is mentioning, is it simply a bolt that all the others a connected to or some special piece of equipment?
As fAR as the 6v setup, I'm not too keen on that for various reasons, the most obvious being if a batt goes bad in the middle of your trip well that puts a damper on things.
โMay-20-2014 11:38 AM
CManley wrote:Just to get my dumb question of the day outta the way, the 6v will charge normally off the rv without any mods, etc correct?
Yes they do. You are connecting them in parallel which provides the 12v source. I typically get 4 to 5 years out of the Golf Cart Batteries.
โMay-20-2014 10:58 AM
