Weber BBQ mod
rwbradley
I am finally getting around to documenting the mods on my trailer and since this one has come up a number of times I thought I would share it for anyone who is thinking of doing the same.
I have a Weber Q120 BBQ that I wanted to mod to use with the trailer propane port (see pic)
So I followed the following instructions from the net to do it
What I had:
- a Weber Q120 with the original thruway bottle regulator
- a 1/4" BBQ port on the trailer with shutoff
I ended up having to get the following:
- 10' gas hose 1/4" to connect to quick release with shutoff valve on trailer
- 1/4" shutoff valve with 1/4" quick release to go on the BBQ side of the hose
- 1/4" quick release for the BBQ to connect to hose
- 1/8" to 1/4" adapter to connect quick release to burner on BBQ
- roll of gas tape
I got the parts at Lowes and my RV dealer
Hose with quick release
BBQ
You can also put a quick release on the old regulator so it can be reattached to the BBQ if necessary to run on a throw away bottle or also to attach an external 20# tank if you want the flexibility.
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
Rob
rvtechwithrvrob.com
14 REPLIES 14
mrgreetis
Does anyone know if the model 250 quick connect (female) would match for fit on the quick connect (male) on the Mr Heater Big Buddy propane heater? Thanks.
johnwalkerpa1
I did the same thing...work great...in addition, I added a quick connect to the original weber regulator...that way I can easily use the 1 pound cylinders if I want to take the grill farther away from the RV.
Ron3rd
Here's how I did my Weber Q back in 2013:
Weber Conversion
Equilizer Hitch
Honda EU2000
tragusa3
Thanks for the thorough write up. I've seen several, and yours is the easiest to follow.
I'm buying a Q200, I hope it will work the same?
New to us 2011 Tiffin Allegro Open Road 34TGA
Join us on the road at Rolling Ragu on YouTube!
Ron3rd
Disneyfix wrote:
So you skipped the regulator all together? The webber regulator is not so great. I've already had them replace one.
On mine, I took the regulator off since I'm drawing regulated gas off the trailer. Don't need 2 regulators in the system.
Equilizer Hitch
Honda EU2000
Disneyfix
Ron3rd
Tachdriver wrote:
I did the same thing, works great.
I did the same thing with parts from Calore too. Works great Easy mod, thanks for taking the time to help others. As I recall, I unscrewed the regulator with my hand, didn't even need a wrench. The only think I left off was the shutoff on the hose. My trailer has a hose that pulls out of a mouse hole and has a shut off.
Equilizer Hitch
Honda EU2000
dsheets
This was exactly what I was looking for. Thanks for posting.
Tachdriver
rwbradley
4huskers wrote:
Nice job, When I tried it I couldn't get the regulator to break loose. After seeing this with the parts listed I'll try again.
I recall it took some force to break the seal. I think there was pipe dope on it just to make me work harder...
Rob
rvtechwithrvrob.com
PatrickA51
Looks good nice write up. Thanks for posting it.
4huskers
RoyB
Good write-up
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
haydoracin
Very nice!
Hayden & Jan
1994 Southwind 33L P-Chassis 454
2006 Chevrolet HHR
OTY (Mini Dachsund)
