May-19-2013 07:15 PM
May-21-2013 08:38 PM
DZacco wrote:
Granted, the cooler is/was a problem (easily fixed with the 6.0 cooler)but the main problem is the solenoids and clutch pack in stock form. These transmissions are modifiable to 1,000hp+ by the right builder such as Brian's Truck Shop in Lead Hill AR. There are a few builders across the country who do this as well. They will custom build and match the transmission to your power and towing requirements. My 2001 F250 was putting down 460hp with 1050lbs torque on the dyno and it still would not keep up with my stock Duramax and the 6spd transmission when towing, especially in the mountains. The 4spd was always out of the power band. It had a higher low gear and lower hi gear ratios with fewer gears in between. Sure, the Ford would smoke the chevy (literally) when I poured on the coal but exhaust temps would go through the roof. If I could have put the 6spd Allison behind the 7.3, I would still be driving the Ford. Except for the tranny, the Ford was a superior truck in every respect. Brakes, steering, build quality, durability, you name it and it was all truck, not a SUV hybrid.
May-21-2013 08:19 PM
May-21-2013 07:21 PM
Atom Ant wrote:
Transmissions were awful.
May-21-2013 06:45 PM
May-21-2013 03:44 PM
butchfuzion wrote:
Remember too that not all 2003's had the 7.3. Ford changed to the 6.0 in the middle of 2003. The early 6.0's had a lot of problems. Just make sure that the one your looking at is really the 7.3. A lot of times people just assume that a 2003 isk a 7.3.
May-21-2013 10:46 AM
May-21-2013 10:36 AM
May-21-2013 10:10 AM
May-21-2013 06:55 AM
May-21-2013 05:47 AM
suse1023 wrote:LostinAZ wrote:suse1023 wrote:
i'm told that with some modifications my 2001 7.3 dually 4x4 crew can pull (or more importantly--STOP!!) upwards of it's rating--any one know which mods are going to achieve this?
i don't want to walk into a diesel performance shop and be completely ignorant!!
After all the mods you still are going to have a truck with the same GVWR.
this is where i get confused---so many here (and on the horse boards) rave about these trucks, and many pull much over the weight limit---i want to do it well, not on the edge-so am trying to figure out if we should trade in the 7.3 dually 4x4 for maybe a newer 550 in order to be as safe as possible, or if that's just crazy talk and this truck (under 50k riginal miles!) is plenty big for the rig we're looking for.
(under 36ft with a few slides for full timing)
still thinking on it...your responses both help and give me more to think about!!!!
May-21-2013 04:37 AM
May-20-2013 08:52 PM
wkswenson wrote:
One note - Get under and look at the oil pan - if it is seriously rusted could be $3-5K to replace depending on who does it...
May-20-2013 07:34 PM
May-20-2013 06:36 PM
