2018 Montana HC 345RL Delamination
canman
We have a new 2018 Montana HC 345RL. Right after it was delivered we noticed some Delamination just above the outdoor kitchen door about a 8x3 inch spot. I contacted the dealer and was told that the right people would be notified. I haven't heard anything back yet. I figure on Tuesday I will contact Keystone to see what kind of support I get.
I am not familiar with Delamination and wonder if its repairable at a shop or has to go back to factory. Anyone with experience in this sort of thing.I thought we looked the unit over real good, don't know how we missed it. I would attach a picture but not sure how to do that. Sorry.
2018 Montana High Country 345RL
2018 GMC Sierra 2500
Enjoying The Retired Life
11 REPLIES 11
Aridon
While it's possible the factory did a bad glue and vacuum job, it is also possible you have a small leak causing the delamination.
Make sure everything is sealed so it doesn't get worse.
Don't trust the dealer on anything, contact the manufacturer immediately.
2019 Grand Design Momentum 395
2018 Ram 3500 DRW 4.10
2014.5 DRV Atlanta (sold)
2008 Newmar 4330 (Modified) Sold
Ralph_Cramden
From experience Keystone will not deal with you directly. They have a canned response they give out every time if you're actually able to contact someone, and the person you do contact if you hit the lottery will be a dedicated email/phone answerer, probably from a staffing agency who knows nothing. "Please visit your dealer" will be the response. Don't waste your time trying. They will not deviate from the policy and anyone who claims otherwise is full of it. It was not that way prior to around 2013.
Too many geezers, self appointed moderators, experts, and disappearing posts for me. Enjoy. How many times can the same thing be rehashed over and over?
billyray50
Got any pics to post.
WNYBob
I agree with "ksg5000"! It's a big deal. Patching delamination is just that a patch. The reason for the delamination is probably moisture in the luan, and most likely from a leak in a seam.
I believe we should boycott the use of wood backed fiberglas in RV's. Especially when better materials like Asdel is available!
ksg5000
Everybody has their hot buttons - delam is mine. If I purchased a new rig that develop delam I would be pushing for a replacement. It's akin to cancer - it might be treatable but anyway you cut it it's a big deal and you buy NEW to avoid delam.
Kevin
jjj
I have a Keystone Challenger fifth wheel that developed a 3x8 oval delam spot. I took it to my dealer and they repaired it. You barely could see where they fixed it except for the area had to be painted to fix it and you could see the gloss of the paint versus the fiberglass texture. Last year it came back with hairline cracks around the whole oval area. I am going to find a graphic to put over it to cover the cracks. Just letting you know that spot may come back later but without the bubble of the delam.
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
canman
Thank you the good replies. I will get in touch with dealer Tuesday and see if a work order has been generated along with pictures.
This is on the curb side slide out that has the outdoor kitchen and dining table.
downtheroad
...and make sure you check around the rest of the trailer for any other signs of delam...
Good luck with it and get active..don't let them wear you out by slow rolling it.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
rjsurfer
Make sure dealer sends in a work order, without a work order Keystone support won't do anything but record your complaint. Many dealers are lazy in that respect.
Also make sure the dealer sends pictures of the defect, again Keystone won't do anything without proof.
Ron W.
03 Dodge 2500 SRW,SB,EC
2018 Keystone 25RES
DRZ-400SM
DL-650
donn0128
This is on the side or back? My guess it will get fixed by the dealer.
canman
Excuse me. I have to change my signature.
