5th Wheel Hitches
prairierattler
I'm a newbie to this site. I am considering the purchase of a 2013 Crossroads Cruiser 5th wheel. I currently have a Travel Trailer. Would appreciate any thoughts anyone has on best types of hitches. I have a 1 ton Chevy Duramax long bed. Also thoughts on the Crossroad Cruiser 5th wheels. Trailer will have GVWR of 12K lbs.
30 REPLIES 30
Tango__AE7UI
I'll second the choice for the B&W.
I don't want any other hitch.
2007 Tango 2660RKS Fifth Wheel, 2006 Chevy D/A 3500 with service body,
Cummins12V98
For those thinking about a replacement of new 5er hitch realize the B&W only sells a very small amount of hitches compared to Reese, Valley, Husky and so on but it really tells the story of how many people say buy a B&W because they are so happy with theirs.
Had a RBW I thought was good until I bought a B&W, looking back the RBW was a noisy clunky hitch.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
Thats_Ok wrote:
Husky 16K S here...
Went low cost because the place I bought from said no need to spend more.
The slide bar types can be a bear to release when TV and trailer aren't on level ground.
I might want to swap heads out if un-hitching continues to be difficult for me.
Hope you find the one!
Regards,
jim
Amazing, you have a dually and they not only sold you a hitch that is hard to use at times but they also sold you a 16K model. Bummer!
Hamops
Although I might have missed it in one of the replies, I suggest that you stay away from a Universal mounting kit for the hitch. Regardless of the brand of hitch that you choose, buy the matching purpose made frame mounting bracket for the hitch.
Cheers
Helen & George VE3INB and Max (Bichon Frise)
2006 Silverado 2500HD D/A, Isspro Gauges, Linex, Westin Nerf Bars, Fold-A-Cover
2014 Avalanche 295
Reese 16K Slider, Bedsaver, Prodigy Controller, Rearview Camera
ependydad
Another B&W Companion vote.
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
57_Panhead
We have the B&W Companion and am extremely happy with its performance.
Steve
Retired Teamster
2012 Jayco Eagle Superlite 31.5RLTS
07 F250 PowerStroke
U Y B
Roads_Less_Trav
We've been very happy with our Pull-Rite Super 5th
2007 Hitchhiker II 34.5 RLTG Fifth Wheel
2007 Dodge RAM 3500 Long Bed / Single Rear Wheel
Traveling full-time in an RV and sailboat since 2007
Our full-time blog: http://roadslesstraveled.us
-Stories, photos, and lots of RVing tips!!
Traveler_II
Another vote for the TrailerSaver, weโ€™ve had ours for about 2 years now and itโ€™s a great hitch. In fact we are in the market for a new truck and the main thing I want is a truck that I can still use my TrailerSaver in, basically a long box.
They do make an attachment that I can add on to the TrailerSaver to make it a slider, but itโ€™s manual and Iโ€™ll not sure I want to go that way.
2011 Cameo 34SB3
2014 Ford 350 King Ranch, Trailer Saver BD3 Air Hitch, Mor/Ryde pin box, IS Suspension, Disk Brakes
Nights Camped in 2012 - 142
Nights Camped in 2013 - 186
Nights Camped in 2014 - 185
Nights Camped in 2015 - 231
Nights Camped in 2016 - 162
hone_eagle
retispcsi wrote:
First question is how much money do have to spend. The air hitches are nice and worth the money but they are expensive. As far as the other hitches my vote is for B & W. American made in Kansas, great company with great support.
Very expensive and even worse heavy,a lot of TV's here are run on a knife edge - re weights, and a elaborate hitch just the last straw.
but so very s m o o t h ๐Ÿ˜‰
2005 Volvo 670 singled freedomline 12 speed
Newmar 34rsks 2008
Hensley trailersaver TSLB2H
directlink brake controller
-when overkill is cheaper-
retispcsi
2015 Mobile Suites 38 RSSA. 2014 Ram CC DRW 4x4 60 gal RDS Aisin 4:10.
DW, Shadow, Remington and Ron. Living the good life till the next one arrives.
azdryheat
Hitches? They will all do the job. Any 16k hitch will work for you but don't get a slider hitch as you won't be needing one with your long bed. Also, with your 1T Duramax you can get a whole lot more trailer than what you're looking at.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
Norskeman
I have used a Husky 16K hitch since 2003. When I purchased my 2011 Chevy I installed the Reese Custom Base and Rail Kit - only drilling required is in the bed of the truck.
http://www.etrailer.com/Fifth-Wheel/Chevrolet/Silverado/2011/RP50066-58.html?vehicleid=2011303929
Buy the RV locally if you can - less distance to travel for warranty work. Find the layout that you like and hope for the best on the Manufacturer quality control.
CrossRoads is owned by Thor as well as allot of other RVs.
http://www.thorindustries.com/corp/recreational-vehicles
I have a CrossRoads fifth wheel - the first year it spent about 4 1/2 months at the RV dealer for warranty work. The bed slide required a major modification - wrong design of the bed slide support with the SCHWINTEK IN-WALL SLIDE System and improper sealing when built. The dealer took forever to perform the modification and they messed it up so it spent another month at the dealer. Bed slide is working good now and no leaks.
As far as CrossRoad trailers - look at the postings on:
http://forums.crossroadsrv.com/forum/default.asp
What year is your Truck?
We used a CAT scale to weigh the truck/trailer this spring:
Steer Axle - 4900 lbs
Drive Axle - 6060 lbs
Trailer Axle - 9220 lbs
Gross Weight - 20,180 lbs
Our 2011 has a GVWR of 11,600 lbs. Axle ratings - 5600 lbs front and 7050 lbs rear. Truck weight is about 7900 lbs - local transfer station scale
Our CF335SS has axles rated at 5200 lbs each.
Weight leaving the factory was 10,014 lbs "dry".
2017 Keystone Avalanche 320RS
TV - 2011 Chevy Silverado 3500HD LTZ CCLB Duramax SRW 4X4
hone_eagle
cwill925 wrote:
spindrift wrote:
cwill925 wrote:
If I ever pull with a pick-up truck again, a Trailer Saver will be in the bed. Trailer Saver
Not to derail but how is this different from the TriGlide Trail air setup?
You get basically the same response from either the Trailer Saver or the Trailair Tri-Glide Air Ride. Both will soften the shock to the trailer. Itโ€™s simply a matter of personal preference. With the air hitch on the truck, it can be used on multiple 5th wheel trailers and even gooseneck connections with a simple head swap. The Trailair Tri-Glide Air Ride is captive to the trailer itโ€™s mounted on. Either way, air hitch or air pin box, you get a greatly improved ride in the truck and less shock to the trailer.
Actually you get a order of magnatude more range of motion with the air ride hitch over a air ride pin box,plus bigger the bags are the less air pressure you need and again more of a pillow ride.
Remember at about 90 psi air bags are basicly solid rubber.
Newmar 34rsks 2008
deleted-2
Husky 16K S here...
Regards,
jim
