Jun-09-2014 06:24 AM
Jun-17-2014 01:15 PM
Jun-17-2014 01:14 PM
Jun-17-2014 01:00 PM
Jun-17-2014 12:40 PM
Jun-09-2014 05:04 PM
Jun-09-2014 04:52 PM
Jun-09-2014 01:02 PM
Jun-09-2014 09:19 AM
Jun-09-2014 09:09 AM
Jun-09-2014 09:05 AM
kennethwooster wrote:
Knowing the brand of the hitch would help. I've used about 5 different hitches and they all work different. One basic thing to do is never high hitch. This will cause you to drop the trailer. I now have a B&W and as long as instructions are followed it will hitch perfect. Pull the handle and place pin through hole and you know it is hitched correctly. Man that installed the hitch told me he sold one to a couple and warned them not to high hitch. They did, and pulled off and down it came Most hitches are this way. I let the hitch pick up the trailer and it usually slides right in. Don't pull until you figure out the problem.
Jun-09-2014 09:02 AM
luggage wrote:
I moved my 5t wheel camper at my home today because I noticed the Wheel Masters level on the King pin tongue was a bubble and a half off to the left. We've had a lot of rain and the gravel drive is not completely level. Well I hooked it up and the coupler on the hitch closed. But apparently not completely because the handle that opens and closed the receiver latch is completely returning to the closed position and not matching up with the hole on the hitch to place the locking pin through it. I am very new to fivers coming from a TAG and still getting use to the hitching and unhitching. What should I do to get the locking coupler to completely close so the handle will seat properly. I hope I have explained the issue clearly. Apologies if I sound clumsy. Thanks
Jun-09-2014 08:33 AM
Jun-09-2014 07:29 AM
Jun-09-2014 06:48 AM
