7 pin plug question
Colo_Native
I have my new FW and was wondering when parked over night say in a Walmart lot with no power source do you leave the FW plugged into the truck and does it draw off the truck battery?
2015 Winnebago Forza 34T
pushed by a 2011 Fusion Hybrid or 2020 Escape Hybrid
Retired DFD
13 REPLIES 13
RustyJC
Arcamper wrote:
My new Ram keeps the plug hot all the time.
Every Ram (Dodge) I've owned since 1996 does. They do not use a battery isolation relay in stock configuration.
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
Arcamper
2016 Montana 3100RL Legacy(LT's,Joy Rider 2's,disc brakes)
2014 Ram 3500 DRW Laramie Cummins/Aisin 14,000 GVWR
2014 Ford Expedition Limited, HD tow pkg
2016 Honda Civic EX-T
1999 Stingray 240LS
1994 Chevy 1500 5.7 PU
2018 John Deere 1025R
B&W RVK3600 Hitch
laknox
tdst51 wrote:
tvman44 wrote:
Agreed Ford factory wired do not because of relay.
I wish mine did. We had to move out and away from the driveway and I left it hooked up for about 3 weeks, and when I went to move it back, guess what? Dead battery in my truck.
Any time you're stopped more than 1-2 days, you should unplug from the truck. Even with a battery disconnect on your trailer, you should still unplug.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
tdsxt51
2014 RAM 2500 CTD 6.7 CCLB Auto
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/ Diamond Pkg.
Old-Biscuit
MFL wrote:
Old Biscuit, on the newer Fords, the top (indent) is at the 3 o'clock position. So yes, you are correct, if the plug was installed like picture, the battery/charge would be at one o'clock.
The Fords have the 4-pin, and 7-pin, side by side, their reason for doing this. I actually like being plugged in with the door on the right, rather than the top.
Jerry
OK.....
Orientation makes a difference.
MFL
Nomad II
Nomad II
Jerry
RustyJC
Normally reference to pin positions is made relative to the plug keyway that's at the 12 o'clock position by definition irrespective of receptacle orientation.
Rusty
B&W RVK3600
Colo_Native
Old-Biscuit wrote:
Colo Native wrote:
Old-Biscuit wrote:
Flip open 7 pin receptacle cover on truck and test for 12V at 1 O'clock blade.
Truck key off.........no 12V------no drain on battery
Even if there is 12V power with truck key off........overnight stop should NOT drain truck battery unless trailer battery is really low/bad
Boondocking-----YES unplug
I went and checked and mine is the 10 and 5 o'clock pins and there is no power when off. THANKS Everybody
That sure isn't trailer/rv standard truck receptacle wiring
10 (11)....S/B tail/running lights & 5 S/B .....brake controller output
Did you have to rewire your trailer cord plug to match truck receptacle?
It is a factory plug and it is turned 90 degrees
Retired DFD
Old-Biscuit
Colo_Native
Retired DFD
Old-Biscuit
tvman44
Papa Bob
Husky 16K hitch, Tekonsha P3,
enblethen
Most factory wired Ford connectors are powered through a relay that disconnects when the engine is hut off. No need to unplug!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
