Aluminum vs Fiberglass siding
Nevadastars
Looking at used toy haulers and I have my eye on one that has smooth siding and there is some delamination in the nose. What is it that makes the smooth siding worth more, especially if it is prone to delaminating?
2016 Forest River Wildcat Maxx 262RGX 8,268 UVW 11,754 GVWR
2007 Ram 2500 QC SB 4x4 Smarty tuned 5.9 Cummins
B&W Turnover Ball & Andersen Ultimate
7 REPLIES 7
Nevadastars
Thanks for everyone's input. I think I have decided on the one we are buying and it is new, not used. It is a 2013 front bath Forest River Stealth 23ft and just happens to have smooth siding. I could not pass it up for the price, $14k off retail.
N-Trouble
I will never buy another aluminum sided trailer again as the only real benefit I can see are a slight weight savings. All other advantates go to Fiberglass IMO.
-Better insulated from cold/heat
-Better insulation from sound
-Less places for water intrusion
-More aerodynamic
-Easier to clean/wax
-Doesn't look like it came from a 1980s trailer partk...LOL
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
Y-Guy
Moderator
Moderator
Should mention that most aluminum sides are made with wood framing while fiberglass uses aluminum studs. Both have advantages & disadvantages.
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
Oaklevel
The smooth siding generally are more expensive to build than the Alum. sided...... Other than that it is mostly a looks thing...... I have Alum & very happy with it.....
skipnchar
Filon sidded trailers are not PRONE to delamination though it does sometimes happen. It's pretty rare and usually has a cause. Both types of siding have their advantages and disadvantages. Filon siding is very tough to damage (hail, tree branches etc) where as aluminum siding dents easily and a good hail storm will "do a number on it". Aluminum is lighter weight but creates more complex wind currents while towing. MOSTLY it's a cosmetic issue as most other things are pretty much "one from column a and one from column B)
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
Bumpyroad
after a hail storm, you will be glad you have fiberglass.
bumpy
Y-Guy
Moderator
Moderator
Mostly looks, but also bit more insulation factor.
