Anyone fix a slide seal with FlexSeal tape?
riflegunbuilder
I've got a 6" split in a slide seal. From research looks like the slide has to come out as Open Range uses U type seals. Thinking of using FlexSeal Tape for a temporary fix. Any other ideas?
11 REPLIES 11
gar_fanatic
Have you thought about eternabond tape? It's been a few years since we used it, but we used to make roof repairs with it and it would work fine.
Me, my DH, my DD (15) and DS (11)
In the market for a new rig.
'07 Ford F-550 crew cab 6.0L PowerStroke diesel "the haulin hawg"
Farmers-Working hard now to play hard later
:W
alaska511
minnow wrote:
tf the tape is like their stuff in the can then no it won't work. In my experience Flex seal wouldn't even stop a dripping rain gutter.
Yep, that stuff is a joke. Luckily, I received it free, and had no notions of success. I love the commercials, though.
We played with it at work on cracked 5 gal buckets, rain gutters (applied on inside, and outside of gutter), and a couple of other ridiculous cheap attempts at ghetto repairs.
2017 Wildcat Maxx 295
2015 Silverado LTZ Duramax/Allison
BarneyS
md_procouple wrote:
Gorilla tape will not hold after a period of time... found that out personally, it like other duct tapes will loosen, peel etc. It just holds up a bit longer. Good Luck and Happy Camping !!
That was my experience also.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
md_procouple
Vickie, Me, and "Scruffy" our dog make THREE
:W
shadows4
What about Gorilla tape?
2016 4X4 F350,CC,SB,Lariat,6.7L diesel,
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
minnow
downtheroad
Nothing to loose. Give it a try and please report back on the success or failure.
I'm always interested in learning.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
DutchmenSport
Well, if that stuff will hold an aluminum boat together that's been sawed in half down the middle, I suppose it would hold on your camper!
But! Who in their right mind go about sawing perfectly good boats in half! :h Kind of like, jumping out of a perfectly good airplane at 5000 feet!
schlep1967
I had to replace the seals on my Open Range. You can remove the U type of seals (actually more of an "H" style) without removing the slide. I didn't have to do the top one yet but I am not looking forward to it.
If I recall there were about 50 staples both inside and out on the side of the H that extends over the wall or away from the slide and a screw both top and bottom. The only place I could find those seals was from Open Range.
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
Ed9824v
check with steele rubber company, they now make RV seals
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
md_procouple
I've never heard of it, but hey it will be interesting. to see what others say. From all the commercials I've seen on the tape, I don't see why not, at least for a temp. repair. Good Luck and Happy Camping !!
:W
