Jun-15-2013 07:15 PM
Jun-19-2013 04:53 PM
Bird Freak wrote:
Sorry, probly took it wrong. I am used to all the attacks here from the know it alls.
Jun-19-2013 02:19 PM
Jun-19-2013 01:21 PM
Bird Freak wrote:BeerCan wrote:.Yes Really!! before you correct me you should look at the correct hitch, Pullrite model 2700. I know what I have. Do you?Bird Freak wrote:
I don't see the big deal with the Pullrite. Mine weighs less than 200# and I can remove 1 set screw and anyone can pull my 5er. I also use a engine hoist to remove hitch. Too dang old to lift heavy stuff now.
Really? According to the manufacturer it weighs 345 lbs plus 50 to 80 lbs for the rails. Did you modify yours?
Pullright Manual
I think the op is looking for lighter weight options. I use the Demco Hijacker and like the Pullright it weighs over 300lbs. I like the way it works but I had to get an engine lift to put it in the truck. Look for used engine lifts for cheap on craigslist.
Jun-19-2013 11:39 AM
Pullright Manual
Jun-18-2013 10:41 AM
Vulcaneer wrote:
You have a lot to learn. The PullRite can be removed by one person. I do it when needed. And I am 68 years old. Tip it up and 'walk it' to the back of the truck. Drop it onto a table that I made to the same height as the tailgate. Then roll it into the garage. Five minutes and no help needed.
The quick connect capture plate can be removed with one bolt and your trailer can be towed by any fifth wheel hitch. The universal rails can be completely removed from the truck bed.
The Hijacker is pretty much the same. But customer service may be somewhat different.
The Sidewinder will work too. but chances are, you need a new replacement for the next trailer you buy.
If you want an auto slider, these are you only options. Otherwise go for a manual sliding hitch and deal with the issues with that choice. Or don't buy a sliding hitch and believe what the trailer manufacturers claim. You can turn 88 degrees with no problem. Just remember when it blows out your window, it is no problem for them. But your mileage may vary.
Jun-18-2013 07:30 AM
ol Bombero-JC wrote:The new capture plates are held on with one setscrew. No need for an adapter. Takes two minutes to remove it, then it can be pulled by any standard hitch...The days of the old weld on and bolt on plate with 6-8 bolts are long gone...BlackSS wrote:
.........and will not put me in a situation where I am the only one that can pull the trailer (like pull rite).
Pullrite conversion adapter #3336 will allow your trailer to be pulled by a NON-SuperGlide hitch.
(The head of your hitch does have to be used on the adapter)
Pullrite Conversion Adapter #3336
However, it will set you back about (another) $175..;)
Jun-18-2013 01:54 AM
Jun-18-2013 01:14 AM
BlackSS wrote:
I though the pull rite was ~350 lbs, and had no idea was that easy to remove capture plate.
What kind of hoist for $50?
Jun-17-2013 06:09 PM
BlackSS wrote:I bought mine online. It's the 15,000# version they now make a 18,000# model. It's the one that uses standard rails. About $800.00 if you shop online. But you will still need to get rails and a mounting kit and have it installed. I like mine but it is a little heavy to wrestle with.
Found out today after talking to a dealer that pull rite has 2 models, the one with rails in the bed is significantly cheaper and lighter. Was quoted 1500 installed (+ capture plate) and was told less than 200 lbs.
Jun-17-2013 05:01 PM
Jun-16-2013 04:53 PM
Jun-16-2013 12:06 PM
Jun-16-2013 12:01 PM
Jun-16-2013 08:48 AM
