Bed tonneau covers
MrD
Hi all,
I would like to find a hard cover that would fit over my hitch, what do you use and how do you like them, do they keep your bed dry?
Thanks
Mike
Mike and Char
2008 Chev 3500HD D/A Ext cab LB D/A 4x4 dually
B&W companion hitch
2013 Arctic Fox 295K ๐Ÿ™‚
60 REPLIES 60
bkurt710
tri-fold xtang best for me http://www.extang.com/docs/trifecta.html
easy to install and remove
Ginther
I have a Roll-n-Lock on my '04 F250 short bed. Got it on craigslist for $100. It was pulled off a wrecked truck in a junk yard. Couldn't pass up that deal!
My hitch is a Demco HiJacker auto slide. My FW has a regular solid pin box (for now). It has never hit the side tracks for the bed cover.
My only complaint is that my hitch with all the auto slide mechanism is huge. It is about 1/2" too tall to close the cover. I have to pull a pin and remove the head plate from the hitch to close the cover. Not a huge pain in the rear, but a slight inconvenience none the less.
2009 Keystone Challenger 34SAQ 5er
2015 Ford F250 Platinum FX4 SB CC 6.7L Diesel
SanMarMor
I bought my truck used, and it already had a Truxedo LoPro QT installed. I hadn't had one of these before, but I would definitely get one again. They are a flat cover, so if something sticks above the rails it would be a problem, but I haven't had any problem with it. No problem at all with my 5th hitch. The thing I like the most, the cross stays are fastened to the canvass. So when you roll the cover up, it rolls the stays and all. Very easy to roll and unroll, no extra parts to store when rolled. It's the favorite cover I've had, and I've been driving pickups since 1985, and had many covers.
Mark
2007.5 Chevy 3500HD Crew DMax Dually 4x4 w/ Curt Q5 20K Hitch
2011 Sabre 31RETS-6 w/ TrailAir Pin
44 nights in 2013, 37 nights in 2014, 27 nights in 2015, 29 nights in 2016
34 nights in 2017, 27 in 2018
http://camping.morrises.com/
MTPockets1
Lantley wrote:
My Backflip has 4 panels. If I fold back one panel it will not stay in place it will blow over. However if I fold back 2 or more panels they do stay in place. When towing I Have 3 panels folded back and they stay in place.
I could fold the 4th panel back and lock it in place against the cab window to fully expose the bed, however I have no need to do this while towing.
Ditto with mine.... But, when I had the BakFLip on my short bed F350, I had to put it all the way up against the window or my pin box would hit it on turns... Not a problem with my long bed.
2012 3055RL Big Horn - Dexter upgraded axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
Lantley
GoPackGo
To the folks that have the panel-type tonneau covers, such as FOLD-A-COVER, and BAKFLIP - Do they stay in place when horizontally stacked up (open) at the front end of the bed and you are towing ? I also want a hard cover, and I'm having an aux fuel tank installed in the bed. I don't believe any of the retractibles will work as the height of the aux fuel tank is too high (but is below the bed rails). I don't think I want to travel with the panels in the vertically stacked configuration as shown in some of the manufacturer videos I've looked at.
richfaa
we have just a plain ole tonneau cover. We have it to keep stuff dry in the bed of the truck. Before that we had a fold a cover. It kept stuff dry also.
2013 Montana 3402 Big Sky. 08 Ford F-350 6.4L
MTPockets1
MO_Trout_Bum wrote:
Lantley wrote:
homefor2 wrote:
When I save up all my allowance, I'm getting a Roll N Lock bed cover. Surprised no one has mentioned it . Very high quality and good reviews. Expensive but you get what you pay for.
I have found that it's not a matter of which cover you like but which cover will fit without contacting pin box in tight turns. While I like them the most,the roll up type seem to be the worst for my scenario.
The tracks used to support the rolling covers interfere with the pin box during tight turns. I eventually ruined a Retrax cover before eventually going with a Bak Flip G2 cover that fits my set up much better.
Amen to that. What cover works best is dependent on so many factors. For me, the rollup works best, as I get full access to the the truck bed, and can see my fifth wheel hitch, making it easier to hook up. However, I am probably 1/4" from hitting the cover side rail - with the PIN box - in the tighest of turns. Bottom line is, the rollup cover works best in my 2004 2500HD, however I might need to go with somthing like a backflip when I eventually move on to a new truck.
We're on our second BakFlip F1 .... Strong and secure if you have a locking tailgate. When we had the short wheel base truck, the BakFlip was in the way of my pin box on turns so I had to travel with the cover all the way up against the rear window. The current ruck is a long wheel base and the cover just lies flat in the folded position on the bed rails when towing. A great cover.
MO_Trout_Bum
2004 Silverado 2500HD Ext, Duramax LLY, 4WD, 3.73
2012 Keystone Cougar 327RES
IWally
Retrax. 2+ yrs still love it.
2007 Carriage RLS30 - Pull-Rite SuperGlide
2011 Ford F250 Diesel Lariat Crew 4x4
BeerCan
Too Young to Retire wrote:
I have the truck cover USA retractable cover. Keeps the bed dry and looks good too.
TCUSA kicks A** I had one on my F150 and loved it.
soling2003
I like the Backflip G2 also. Even took it with me from my 2010 F250 to the 2011 ford dually. It does have a few dings on the inside now where I either slammed it down on something too tall inside or some such thing. It is nice that you can lay it over something that is just a bit too tall, but make sure you tie it down if you are driving very fast.....or it goes up and down back there like a snake. Even at just 35mph.
DW and 2 dogs
2011 Ford F350 Dually LB 4x4 CC 6.7 diesel
2007 Grand Junction 35TMS
Peterson 37(just sold) T-37 R/C Sailboat at home
TruckGuy616
MrD wrote:
Wow great responses, I'm checking out all the different options. I do have a long bed so that is an issue I'll have to deal with. My companion hitch is low enough so it probably won't be a problem. but my pin box is close to hitting my bed sides on a wide turn and with brackets for the cover it might get even worse. Lots to think about
Thanks for the replies.
Mike
The Fold-a-Cover that I have doesn't take up any extra room inside the bed. The rails sit on top of the sides of the truck bed, giving it an extra inch or so of height, but still plenty of clearance for my fifth wheel.
Here you can see the rail doesn't go into the bed at all.
And here is an extra picture of how it looks on the truck.
Too_Young_to_Re
2018 RAM 3500HD MegaCab,hauling a 2020 Mobile Suites, and loving it.
