Automatic switch over on propane tanks
msgtearley
I have 2 30 pound tanks, both are full. when the one on the right runs out and I try to switch over to the one on the left, I can not get any propane to flow. It is just like the tank on the left is empty, which it is not. I have taken the tank from the left and put it on the right and it works fine. I just am not sure what is preventing the propane from flowing from the left. A regulator is hooked up to the tank on the left and then it goes to the switch over valve. Any ideas on how I can check out the regulator and the switch over valve?
19 REPLIES 19
Earl_E
Dave H M wrote:
I did not understand your second sentence. You mentioned you tried to switch over. That is spose to happen automatically. i do not have any control on my switch over valve. :h
If I turn the valve to left tank, it feeds from the left tank. If I turn the valve to right tank, it feeds from the right tank. When one tank runs out it switches automatically, but I then turn it to the tank that is feeding so I can remove the empty tank. Sounds like control.
2007 Northwoods Arctic Fox 32 5S Fifth Wheel used for fulltiming for several years--SOLD
2014 Sunnybrook 26rl to poke around the smaller parks in the great Southwest
2007 Chevy Silverado 2500 HD Diesel
Prodigy brake control
rseymour21
I like it when there's a problem and solution, maybe he'll come back sometime and report his finding!
2003 F250 7.3L
2008 Cougar 292RK
allen8106
greende wrote:
smkettner wrote:
Could be a stuck check valve in the pigtail that connects valve to the tank.
X2
X3 Happened to me and had to replace both pigtails.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
Ron_Nielson
The EASIEST solution is to stop by your propane dealer (any propane dealer) tell him what is going on and in a few minutes he will diagnose your problem, and likely offer to fix it for you, at a rate probably lower than any place else you will find. And the job will be done CORRECTLY.
RockyMt
Same problem-replaced the red regulator and the pigtail,all is good!
time2roll
Should be a lever to designate the primary tank.
And yes the secondary bottle should feed the RV with no adjustment.
Dave_H_M
edatlanta
My auto switchover regulator failed a few weeks back. A new one solved the problem.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
car2900
Every time I turn my tanks on, VERY slowly, I can't get gas. I have to lightly tap the regulator with a wrench and that does the trick. Think I should go ahead and replace the regulator?
2017 Tiffin Phaeton 40 AH
2010 Chevy HHR toad
Blue Ox Avail - SMI AF-1
greende
X2
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
USAF 1968 - 1972 Viet Nam '71 - '72
time2roll
laknox
I sure like my FW, where the 2 propane tanks are side x side with a single valve T'd between them.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Old-Biscuit
Your RED regulator is bad. They reduce cylinder pressure down to 30# and then feed across rig to other side and main regulator.
jdgreen42
The safety valve on the affected tank is likely stuck in the closed position. Disconnect the pigtail hose, be sure the tank valve is turned OFF. Insert a small flat screwdriver in the opening against the valve seat and give it a quick rap with the palm of your hand. Be sure the valve is OFF before you try this. You should hear a quick short hiss. Reconnect your pigtail and open the tank valve SLOWLY. It should work as normal.
Don
