Dec-20-2015 05:41 PM
Moderator edit to re-size picture to forum recommended limit of 640px maximum width.
Dec-22-2015 03:08 PM
IdaD wrote:
Yeah, a 5 link coil setup and a swaybar vs leaf springs. That's it. The axles, frame, brakes, drive train, tires and everything else on the truck is the same as 3500.
Dec-22-2015 02:31 PM
jerem0621 wrote:IdaD wrote:omextreme wrote:
The Anderson has a couple of adjustments. One is how you orient the hitch itself (can be forward or aft of the gooseneck), and the other is how you orient that kingpin adapter. I believe in total you have about 8" of potential offset between the two of them.
Yes the anderson can be set further back, But sadly Like so many others I failed to research the Cargo Capacity side of things when I Bought the 2500. I was trying to keep the pin centered or slightly ahead of the rear axle since I am so close to max capacity...
The rear springs on your truck are literally the only thing different from a SRW 3500, and they can handle a 3000+ lb load without issue (the 6.4 version of your truck weighs about the same empty at the rear axle but has a payload rating of around 3300 lbs if I'm not mistaken.)
Anyway, in the future I'd pay more attention to your 6500 lb RAWR and flip that Anderson around to give yourself an extra margin of error. I'm glad you brought this up though as it might explain why this accident occurred.
I am pretty sure that the rear suspension configuration is totally different from a 2500 Ram to a 3500 Ram.
IIRC the 3500 Ram SRW has traditional leaf spring suspension and the 2500 has 4 link suspension with coils. So, its not exactly like the old F250 to f350 SRW where you just swap springs and blocks and viola a 3500 is born.
Thanks!
Jeremiah
Dec-22-2015 02:06 PM
Dec-22-2015 01:08 PM
IdaD wrote:There is literally only about 200# difference between the forward and rearward positions. I don't think he would even notice the difference. I have the hit in my 2500 mounted 6" behind the axle and everything handles and drives great.omextreme wrote:
Dec-22-2015 01:05 PM
Thanks!
Jeremiah
Dec-22-2015 12:40 PM
Dec-22-2015 12:07 PM
Cummins12V98 wrote:
"I don't see how the B&K RVK3600 could replace a slider hitch"
I have no personal experience but some will run the 3600 in the rear most position and have had no problems.
I think everyone knows I am a BIG B&W promoter but "IF" I had a SB truck and had a slider it would be the PulRite auto slide. I would probably forget to slide back the manual slider as our friends did and blew out their rear window if I had the B&W.
Dec-22-2015 12:02 PM
Dec-22-2015 11:15 AM
Dec-22-2015 10:47 AM
Dec-22-2015 10:30 AM
Dec-22-2015 10:13 AM
Dec-22-2015 09:10 AM
NC Hauler wrote:Me Again wrote:SoundGuy wrote:
Unfortunate to be sure but as you say this should remind others towing with a short bed that a slider should be considered mandatory, not optional.
I had numerous people tried to talk me out of a slider, stating that the Andersen or B&W RVK3600 would work fine. And they do until you hit!
Chris
I've ALWAYS recommended using a slide hitch in a short bed truck. I had a Reese slider in a short bed Chevy years ago and hit the upper drivers side back...put a dent in about same place OP did, but opposite side...made sharp left turn and I should have used my slider, but didn't...and paid to fix the dent....I never "assumed" I could make a sharp forward turn after that...next truck was a long bed:B
My philosophy for a short bed truck was/is: It's better to have a slider type hitch and never need it, then to need one and not have one.
I don't see how the B&K RVK3600 could replace a slider hitch:h... I know the Andersen has two positions for the hitch ball....one position for long bed and one for a short bed, but that is about all I know about the Andersen.
Dec-22-2015 09:02 AM
omextreme wrote:up2nogood wrote:schlep1967 wrote:omextreme wrote:jerem0621 wrote:
Would the hitch be cheaper if ordered online?
Thanks!
Jeremiah
Yes definitely, and I will price them out again however whenever possible I really like to try to buy at the local shops. As long as they are within a few hundred dollars of the online price Ill go through them.
It is always nice to get a cheaper price on something but when I have that friday afternoon issue that a good RV shop can solve for me and its out of business there is no comfort in knowing I saved a few hundred bucks over the years buying cheaper online.
Now with that said... If i can save $500 bucks or more then budget wins over my desire to help local business... I have to feed the kids
Getting the hitch might be cheaper online. But the delivery guy does not install them. Pay the dealer that has installed them before. Odds are they have at least some clue as to what they are doing.
Thats true the delivery guy does not install, BUT hundreds installl their own. His estimate is a total rip off . Aprox $1100.00 to install a $1100 hitch :h
In all fairness the estimate they quoted was for the 21k hitch and the Rail to Puck adapter.... But yes still high and I can Install myself...
