โNov-27-2020 08:13 AM
โNov-29-2020 05:07 AM
โNov-29-2020 03:25 AM
NRALIFR wrote:
Hereโs a helpful item if you typically use the boxes or jugs of DEF. this is a Ford part, and you can order it on Amazon for about $10. It fits on any jug or box of DEF, and I *believe* the DEF fill ports on vehicles are all the same, so the o-ring on the dispensing end of the spout will make a seal when itโs pushed down into it. You can then turn the DEF jug upside down if you want and there will be no leaks. The DEF tank will fill until itโs full, and nothing will spill out. Itโs a handy item.
โNov-28-2020 07:11 AM
โNov-28-2020 05:40 AM
โNov-28-2020 04:32 AM
โNov-27-2020 09:16 PM
rhagfo wrote:Lynnmor wrote:
DEF is DEF, buy whatever has the lowest price. I do have concerns with dirty nozzles at truck stops, but many use it with no problems. Walmart most likely has the best price on their own brand.agesilaus wrote:
As noted DEF is DEF is DEF. It is all the same, save yourself some money and buy the $7 stuff from Walmart.
So you are both certified chemist that have tested all brands of DEF on all counts including purity.
The effects of less pure DEF likely will not appear right away, the same as using cheap engine oil will only build sludge which leads to issues down the road.
As often as I need to add DEF I will use a brand name.
โNov-27-2020 06:34 PM
โNov-27-2020 05:49 PM
โNov-27-2020 05:36 PM
โNov-27-2020 04:13 PM
โNov-27-2020 02:49 PM
โNov-27-2020 02:48 PM
โNov-27-2020 01:43 PM
โNov-27-2020 01:25 PM
โNov-27-2020 09:46 AM
