Building a RV garage input needed. Pictures helpful
fly4fun
Finally got settled in the new house so now its time to build my RV garage. I am going to have a 40ft wide by 50ft deep. My question is that I think I would like to have only one door 12 wide by 14 high in the center verses putting in one high door for the rv and a smaller one for my boat.If I go this route will I be able to put my trailer in all the way to the back ( 32ft ) and still be able to angle my bass boat in and out fairly easily? I use my boat alot and the trailer not as much. Any thoughts would be appreciated and pictures of what you have built would be even better. Come on guys, show us your man caves!
40 REPLIES 40
SolidAxleDurang
My building is 40x50. Red-iron/all steel construction - so it's fully open span.
Two 12'w by 14'h doors, I can drive straight through the center (the 50' direction).
Also have a 16'w x 8'h two-car garage door on the side...
Plenty room inside for 40' RV.... 2 jet skis (18' length trailer).... vehicle inside if i desire (we have a 3-car garage as well), and lots of other "junk".
TV = 15 Ram 3500 Dually 6.7 / CC-LB / CTD / Aisin / 3.42 / 4wd / EBrake
5er = 12 Keystone Avalanche 330RE
Toys = 08 Kawasaki Brutie Force 650i 4x4 ( x2 ๐Ÿ™‚ ) 14 Arctic Cat Wildcat 1000
Campinghoss
I had a shelter 41 feet long 32 feet wide and 19 feet high at center built a few years ago. It handles the bass boat, fiver, F 250 and a few other smaller items just fine. The contractor talked me into not closing it in so I could just drive thru. The contractor said if I was not happy he could easily come back and put in garage doors. It works fine just as it is. Of course I have a large attached garage on the house that I use as my shop so it depends on what you want to do out there as far as ends go.
Camping Hoss
2017 Open Range 3X 388RKS
MorRyde IS with disc brakes
2017 F-350 6.7 with hips 8'bed
Lucie our fur baby
Lucky 9/15/2007 - 1/30/2023
Bionic_Man
My building is 52' x 24' x 16'. My door is 20' x 14'. I wish I had your width as mine is tight to maneuver around when my slides are open.
If I were you, I would go at least 52' deep. If you don't, you will have difficulty keeping your truck hooked up to either your boat or your 5er. My 5er is 32' long, my ski boat is 25' long (with trailer tongue & outdrive, and I have a long bed crew. I could not keep my truck hooked up to either my boat or 5er if I went with 50'.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
Jerrybo66
I drew the plans for our Son's RV garage. We considered all uses. The result was 60' long allowing two units end to end. 50' will be adequate for one but will be wasted space because not enough for another. 14' high is adequate door opening.. One 18' door gives enough clearance for two bays of toys. Windows on the side walls give light & ventilation. He's happy with it after a few years of use.. IMO..
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
RCMAN46
Mandalay Parr wrote:
Maybe a 16 or 18 foot wide door
x2
I have a 30x60 shop with a12 foot wide door. When putting 5th wheel next to a wall the 12 foot door gets very narrow.
Mandalay_Parr
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
glazier
I am finishing up a new 30 x 80 x 16' high RV Garage now. I put in 16' x 14' doors in both front and rear to allow me to pull through. I installed skylights every 4th panel on the metal roof ( polycarbonate roof panels) these help a bunch for lighting.
2017 Grand Design Momentum 328M
2015 Chevy 2500HD LTZ Duramax CC/SB/4X4
B&W Companion Slider
Pangaea_Ron
Put the tall door in the center, and a 10' wide boat door to one (or both) sides. Use scissor trusses to gain extra height at the center, and it will help to keep the eave heights lower to save $$$.
2008 Itasca SunCruiser 35L
2014 Honda AWD CR-V EX-L
Artum_Snowbird
Definitely put in two doors, both sides of center, and both should be as high as they can be. RV's command 14 feet high now, and a lot of boats are the same. Why not make it fully usable on both sides, and if you really need it it will be a lot easier to get three lanes out of two doors than one.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
fly4fun
It will be 40ft wide. A 40x50. Never really thought about having to back into a dark shop in broad daylight. Although I will have lots of floresent lights in there. Good thought to ponder though.
B_O__Plenty
Maybe you could but if it's 40 feet wide, why not put a second 10 ft wide door alongside the other one? Then you could back straight in with the boat. Besides it's hard to back into a darkened garage if it's light outside and then turn as well to miss the RV.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
