โJul-26-2019 07:12 AM
โJul-31-2019 07:06 AM
โJul-31-2019 04:44 AM
โJul-31-2019 04:13 AM
โJul-26-2019 02:20 PM
โJul-26-2019 01:13 PM
โJul-26-2019 10:36 AM
โJul-26-2019 10:24 AM
CA Traveler wrote:
With the 5er low point height and distance to the wheels, clearance is a easy calculation with online trig calculators.
Otherwise I'd block the TV rear wheels if necessary.
โJul-26-2019 10:16 AM
โJul-26-2019 10:14 AM
4x4ord wrote:
I take it your ramp is dropping off at a 6 degree angle. So it drops off about 4 feet over its 40 foot length.... in other words at the rate of about 1:10. So assuming your kingpin is 40 inches in front of your tailgate you shouldn't have clearance issues so long as you have over 4" of clearance above the tailgate on level ground.
If the ramp is going up at 6 degrees rather than down and the centre of the axles is 16 feet ahead of the rear of the trailer the ramp will rise 1.6 inches over that 16 feet.... so you won't have to worry about your leveling jacks dragging.
โJul-26-2019 09:37 AM
โJul-26-2019 08:36 AM
โJul-26-2019 08:16 AM
RoyBell wrote:
The ones I am looking at are between 36-39' long, double axle.
Not sure the clear of the door but I think it's 14'.
โJul-26-2019 08:05 AM
