Clunking noise while towing
1911
I am new to driving a fifth wheel, but not new to towing. I just got a 98 31' sea breeze fifth wheel. I am using a 15k Reese hitch with kwik sliders. Any time I accelerate from a stop, there is a loud and noticeable "clunking" sound that comes from the trailer. I used the search function, but couldn't find anything. Does anyone know what might cause this and if it is a real problem or not.
37 REPLIES 37
Artemus_Gordon
Should be looked at by RV tech. Should not cost much to have it checked out!
2012 Montana 3750 Hickory Edition, 2013 Ford F450 Crew Cab 4x4 Platinum options
2012 3750 Montana
Generator Box
UsualSuspect
The clunk is the play between the pins that hold the hitch to the rails and the hitch. When I had my 5'er mine did it from day 1, Reese and the place that installed it said it was normal.
2007 Fleetwood Excursion 40E Cat C7 350 HP
2007 Chev 2500HD D/A Long bed CC (Yes, it is my TOAD :B)
2011 Toyota Tundra
2013 Jeep Wrangler Unlimited Sahara (Backup towed)
Gone but not forgotten, 2008 Jayco 299 RLS
donn0128
We are saying you might have play in the hitch head. Depending on brand of hitch there may or may not be an adjustment. Mine has a hex bolt on the front of the head, that I can adjust to remove the slop between the hitch and the trailer pin.
daveandviv
Does it "clunk" as you are applying your brakes to stop and then again when you start moving? That would indicate that there is play some wheres in your hitch.
2016 GMC Denali 3500 D/A
2017 Jayco Eagle FW 321RSTS
camp-n-family
Trailer brakes releasing slightly later than truck? May need to be adjusted.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
1911
Sorry if this is a stupid question, but what do you mean loose hitch? It locks into the rails tightly and doesn't seem to have any play. Is there anywhere else I should check? That is the only place it contacts the truck.
3_dog_nights
X2 - play in the hitch
Bob & Lynn
2 Chihuahua's, Ella, Gracie
was-2013 Open Range 424RLS,06' Chevy 3500, dually, Duramax/Allison
also was - 2015 Winnebago Adventurer 37F, towing 2003 Jeep Wrangler
now - 2021 NoBo 19.5, 2019 Honda Ridgeline RTL (Talk about downsizing!)
donn0128
Loose hitch would be my first guess.
