Direct TV Won’t Work on my 2018 Montana?
Only_True_Mosno
So something is not working for me. I am getting a Signal 775 trouble communicating with dish. I have 3 connections in the outside command center. 1 for cable..2 different ones that both say satellite.
First question is which satellite connection to use? Bottom one or the one in the middle? ( I have tried all 3 with no results)
Second I am only trying to get it to work in living room. The wall socket says cable for one connection and satellite for the second. ( I have tried both with no results)
So I ran the cable directly from dish into a window and connected to reciever. Works fine.
So I have a wiring problem somewhere and have no idea what to do next???
I am experienced dealing with satellites tailgating and RVing and know it is something in the new RV. There is no green light button in the living room outlet and I turned the green light off in the bedroom with no results. Thoughts?
2018 Montana 3721RL
2018 Ford F350 Diesel
Life Comes Down to a Simple Choice...Get Busy Living or Get Busy Dying...
18 REPLIES 18
JJChomp
We had the same issue. Go to the rear tv and turn off the antenna booster. Problem solved.
John & Jackie
Mandalay 40E
NC_Hauler
GHop wrote:
Don't use Direct TV you will regret it.
Have had DIRECTV for close to 25 yrs, never had an issue that wasn’t easily fixed. Full timing got over a year with auto satellite on roof and a Genie in the living room and slave in bedroom. Never had a problem. Have never regretted it and enjoy it everyday.. as stated zero issues.. works every time.
Jim
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
ChuckSteed
Wonder if the iss7e was resolved ??
garyp4951
I've had DTV with the last two 5er's, and always had to run directly to the DTV box. I don't know what satellite they wired for but it did not work .
ChuckSteed
Well I wonder if he got a meter and homed out the connections or got a cable tester to verify which goes where?
With the proper test equipment it would easy to find what goes where
Also.. I’ve been using GTV for many years and have zero regrets. And in this case the provider service has absolutely nothing to do with the guys isues..
jsrore
We had the exact same problem with our Montana a 2017 when we hooked up directly to the TV it worked fine when I went through the RV wiring it wouldn't work
2016 Montana 3790RD
2015 Ram 3500 Larmie
1998 BlueWater 18',fish/ski Boat
1 DW, 3 Dogs,
United States Navy 10yrs
Life, Liberty and the Pursuit of ALL who Threaten It!
Nothing but the good life,cool breeze plenty of Beer!
GHop
G.H.
golf_bears
You need to do a continuity test on each cable connection to determine which cable goes to which TV and to determine if the cables are actually connected properly at each connection plate.
Not a difficult task and you need a multi meter to do so.
Learjet
Don't know if this helps or not, but in my signature rig the sat. wires are orange and the cable/OTA wires are black, if you remove the plate and look at wires.
Both are direct run from the outside connector to the respective tv.
I have run two Directv receivers at the same time... Genie in living area and H25 in bedroom using the SWiM system with no issues.
Spliter is in the outside bay and power inserter in the Main TV location:
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
john_bet
In my '05 Montana and this '18 Grand Design I must switch a cable connection behind the TV. There is an outlet that has two connector on it with one cable. That cable leads to the TV and that is the one you need to switch to the other connector for sat. input to TV. Not sure where it might be located on your exact unit. You may just have to explore around as I know the books are not good on this subject. Good luck.
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
stickdog
I had a problem with the wiring in our new Mobile Suites the wires were miss numbered 1 outside was 2 inside and 2outside was 1 inside. At least they were different color. Then I had to run the HDMI cable to the sony sound system which is in turn is connected to the TV. Also make sure you antenna booster is turned off.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
DutchmenSport
Probably the actual wire inside the walls of the camper. Like stated above, cheap wire. Not necessarily "cheap", just not designed for Satellite service.
We (use to have) DishTV and had a Tailgater antenna. The DishTV service technician that set us up in the house, sold us a second dish for the roof, only we use it on a tripod for the camper and just brought the receiver with us when camping. He also provided about 50 feet of coax wire. He also informed me that not every kind of coax wire will work.
Sure enough, I tried his wire and later I tried some stuff I had at home. Mine never worked. I always had to be careful to use the correct coax. When attaching to the outside jack on the camper, and then attaching the inside jack to the receiver, it would not work either. Although that distance was only the thickness of the wall, the difference in coax wire, connecting the outside jack to the inside jack, was enough to cause failure. When I stuck the wire through the window and attached directly to the receiver, it worked great!
Later, we purchased a Tailgater. It came with the wire too. We continued to stick the wire through the window and never had a problem again ... well .. until we finally canceled DishTV because their prices kept jacking up and we finally said, enough is enough!
one_strange_tex
You have a wiring problem, but others might want to note that we found that some of the newer DirecTV receiver boxes, especially the Genie, are incompatible with our 2-year old roof mounted Winegard dish.
one_strange_texan
Currently between RV's
Former 5th wheel owner (Montana 3402RL)
Me_Again
Like others have posted, we need more information to help you. To fix this yourself you might have to buy a coax cable tester.
RV manufacturers tend to be coax challenged on connectors, installations, labeling and proper tighten of connections.
Chris
https://www.amazon.com/Klein-Tools-VDV512-058-Explorer-Tester/dp/B004CHVOBG/ref=sr_1_9?ie=UTF8&qid=1...
