Do I have a problem
was_butnotnow
I have a 09 NuWa Discover America 5th wheel. All has been good except I just noticed a slight movement of the lower left front of the 5er on the roadside under the bedroom slide. When connected to the truck hitch with front jacks up there is a slight 1/8" gap between the lower trim and the main body. When just on the front landing jacks it comes back together tight. Wondering if this is just normal after years of heavy use or if I have a frame structure problem.
Now in a 05 Monaco Cayman DP 36 PDQ
Traveled many years in NuWa Hitchhiker 5th wheels.
Travel Journals and Adventures of people living this lifestyle
Hitchitch.com
Personal blog with our own travels. www.fulltime.hitchitch.com
13 REPLIES 13
was_butnotnow
Have read the nine pages of forum posts at NuWa on this issue and for in my case since I just found it and not much movement. 1/8" So will go with a flex sealant and see what happens. It seems the factory sez don't worry about it but seal it to keep water out.
Thanks for guiding me in the right direction to the NuWa forum. My old login and password even still worked on the site.
Just ordered new slide seals and new decals for both sides from Kansas RV (NuWa). Gonna fix it up and use it or might trade. 09 348 SB DA 5er. Last spring got a new rear bumper from them. Thay have all the parts for old Hitch Hiker units and are great looking up want you may need to order.
Hitchitch.com
was_butnotnow
FlatBroke wrote:
Here are 9 pages on the problem. Seam separation
Thanks FlatBroke for the link to NuWa forum.
Hitchitch.com
Splashers3
My Cedar Creek had a structural problem much worse than yours....Denise and her crew at the factory fixed it (and repaired a lot of other inside damage) for free!
Your problem will more than likely get worse...ours got progressively worse over 3 years until things completely failed and all the caulk in the world wouldn't have fixed it.
Looking at our next CC.
Good Luck,
Mike
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
FlatBroke
Hitch Hiker
"08" 29.5 FKTG LS
Me_Again
Time to call the Kansas RV Center! http://www.kansasrvcenter.com/ They are the old NUWA people. They might fix it for free! Road trip!!!!
Chris
Vette_Racer
Had the same issue but mine was moving more than yours, the entire wall moved up about 3/8 of an inch when hooked up. Folks in Chanute at Kansas RV Center (old NuWa) fixed it, no problems since.
KE5NCP
2016 Ram CC Dually, 2011 HitchHiker 349 RSB DA, 2018 Wrangler unlimited Rubicon
naturist
There is a problem only if someone thinks there is a problem. And only because someone thinks there is a problem, then you DO have a problem. Broken stud connector sounds like a problem to me.
dblr
I had the same issue on our Cedar Creek, factory repaired it at no cost to us. Good luck on your repair.
2017 River Stone Legacy 38MB
2001 Kenworth T2000
2009 Smart on the deck.
Old-Biscuit
was_butnotnow wrote:
Old-Biscuit wrote:
YES you have a problem.....broken wall stud at lower horizontal support
That sidewall panel forward of bedroom slideout has to be removed and then wall stud(s) reattached to lower horizontal overhang support.
May have to remove overhang panel and install new 1/2" lag screws thru that horizontal support also. (Install in a 'W' pattern)
So you are telling me I have to remove the outside fiberglass wall?
That's just nuts... Not that you are telling me that but what might need to be done. I have posted on NuWa form for more answers.
Anyway, thanks for replying to my post....
YEP.......
Had to take mine in to factory in Chanute, KS for sidewall repair.
SAME Issue.
was_butnotnow
Hitchitch.com
SH
Doesn't look like much flex to me. Make sure the trim screws are tight. The sealant looks a bit aged. You might try a good quality urethane with a good elongation quotient like Bostik 1100. If the gap returns after using the Bostik start looking for another issue. JMHO
2001 Alpenlite 35RK
2007.5 Chev LMM Duramax/Allison
BD Variable Vane Turbo Brake
TST 507
2010 FLHTC Electra Glide Classic Red Hot Sunglo ๐Ÿ™‚
Old-Biscuit
stickdog
A not uncommon problem Try http://www.nuwaowners.org/forum/
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
