Oct-15-2017 03:35 PM
Oct-18-2017 07:59 PM
Oct-18-2017 06:25 PM
Oct-18-2017 03:32 PM
Oct-18-2017 03:30 PM
Cummins12V98 wrote:
I'm betting it's MADE in USA!
Oct-18-2017 02:20 PM
Oct-17-2017 06:48 PM
Oct-17-2017 04:48 PM
judelaurenzo25g wrote:
I paid $450-500 to install my rails including the brackets and wiring. I paid $100 for a slightly used Husky 16K slider on craigslist. Works just as good as a new one. $650 total, called it a day.
Oct-17-2017 03:56 PM
Oct-17-2017 11:46 AM
C Schomer wrote:
All the bed rails I've seen mount sideways. I think someone mentioned a 4way pivot hitch and they also pivot side to side. I started with a 14k single pivot hitch and soon had to switch to a 4way 15k cuz the single pivot bound up on really uneven ground and I couldn't get unhitched.
I've built 3 rv beds and about to build another and I put the hitch 3" ahead of the axle. When I started rving in the early 90s dealers included a single pivot hitch, installed, as part of a new 5er deal but I doubt if they do that anymore.
I bought my 32' 15k gvw 5er used from a friend and he already put on a 5th Airborn pin box on the 5er and it help a lot. None of my previous 5er weighed over 10k and no special hitch was needed for them.
I think your dually is still rated 12500 towing if you have the 4.10 but your payload goes up higher than my 3/4T did, so around 30-32', depending on how heavy it's built, will probably be your limit for the gvw.
Keep in mind, passengers and cargo in the truck are included in the towing capacity of the truck so estimate that weight and add it to the gvw of the 5er you pick, to avoid going over the trucks towing capacity. Craig
Oct-17-2017 11:38 AM
Reddog1 wrote:
Food for thought. When you exceed 27 feet, you may not have access to some campgrounds.
Wayne
Oct-17-2017 10:22 AM
Oct-17-2017 09:43 AM
Blanco1 wrote:I think that is a good idea, but that will not take long. My thought is ask members here the weights of their 5th wheels. I bet very few if any that are 30 feet are under, are over 15000 lbs. If that proves to be true, watch for a used hitch for $200 or less. I think you will end up with a hitch that uses the side to side rails. You have time to be picky.
I suppose I should start going to all the shows & narrow it down to what trailer weights are in my range before buying the hitch, to help me determine what's the right hitch?
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Oct-17-2017 09:30 AM
Toad: 91 Zuke
Oct-17-2017 09:13 AM
