May-20-2020 07:23 AM
May-22-2020 07:03 AM
May-22-2020 06:37 AM
rhagfo wrote:gattorgetter wrote:
Got a new 2020 GMC 2500 with DMax.
Door sticker says just over 3300 for payload. Tires are 3750.
So... manufacture's say hitch weight for xx toyhauler is.... let's say 3500lbs... im guessing that is empty... now if I load 2000lb in garage... the 3500lbs hitch weight could/should be less?
Well the listed Payload is 3,300# and tires are rated at 3,750# ea.
How about the GVWR, and the rear axle rating.
That and scaled weights of the Truck with a hitch and your family.
I ask the GVWR, as GM seems to be playing games with the GVWR of their 2500's and going beyond the 10,000# max for Class2.
Once a TH is loaded for travel with toys and food, cook ware, stuff, and clothing. the pin will likely a bit more than the dry weight depending on how much stuff you carry.
So even going by tires at 3,750# you could put 7,500# on that axles if ready to tow it scales 3,500# that is only 4,000# for a dry pin of 3,500# you are very close.
I guess my big question is WHY NOT buy at least a 3500 SRW to tow a larger TH.
May-22-2020 04:29 AM
dedmiston wrote:
That's not really such an unlikely thing. Not the theft part, but traveling without the SxS. We take trips all the time without the car in the garage. You definitely want your setup to work whether you're loaded up or not.
I'm still curious to know whether the OP is talking about a 5er or a bumper pull.
May-21-2020 12:46 PM
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch • 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") • <\br >Toys:
May-21-2020 12:30 PM
valhalla360 wrote:
One other issue you may run into is will you ever travel without the toys? Maybe not planned but let's say your side by side gets stolen...now you are driving back with an otherwise fully stocked trailer but nothing in the back.
If the garage is empty, now you have the empty hitch weight plus any weight from household gear stored ahead of the axles. Your empty 3500lb hitch weight jumps to 4000-4500lb.
May-21-2020 07:33 AM
May-20-2020 08:12 PM
May-20-2020 03:18 PM
May-20-2020 03:03 PM
May-20-2020 11:31 AM
May-20-2020 08:49 AM
May-20-2020 08:30 AM
May-20-2020 08:29 AM
May-20-2020 08:28 AM
gattorgetter wrote:Yes, it will be less, sometimes a lot less. It depends on what you're hauling in the garage. Some people have had their hitch/tongue weight drop too much and resulted in poor handling.
May-20-2020 08:12 AM
