Electric help
TheCanuckian
Have a 2012 Bighorn, the one with the living room in the front.
The power just went out on the left side of the living room and outdoor receptacle. Looked for a reset somewhere, none found. Checked the breakers and all are where they are supposed to be. #3 fuse is called off-door side 15a. Pulled it and it looks good.
Any ideas?
Thanks everyone..
Marc
2014 Bighorn 5th Wheel ---- 2012 Cedar Creek Cottage
Marc and Linda -2 Yorkies- LuLu and LollyPop
Endless Summer.... Quebec and Florida
Visit our Blog - The Canuckian🙂
11 REPLIES 11
enblethen
Thanks for update!
At times you need to step away for a while and the answer pops into your head at the oddes time. Middle of the hight for me!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Me_Again
j2catfish wrote:
Take it from an old sparky - you mostly cannot depend on looking at a fuse to determine if it is good/bad. Always try to use a good ohmmeter to check fuses, unless they are really burned up.
JMHO. Catfish 🙂
Receptacle would indicate AC and breakers vs DC and fuses. But good advice for DC issues. Chris
gbopp
DownTheAvenue wrote:
1. Breakers may look like they are not tripped, but can be anyway. Turn off each breaker and back on. You may find a tripped breaker.
x2. I've found this to be the case several times. The breaker is kicked but it looks okay.
Let us know when you find the problem.
ScottG
Yay!
TheCanuckian
Thanks everyone. The problem is fixed. Was laying in bed, listening to the thunder, and it came to me. We have a night light on the plug in the bathroom. It covers the GFI reset button.
Pulled the night light, pressed reset....light went on....both figuratively and realitively.
Niteny-nite.
M
j2catfish
JMHO. Catfish 🙂
K3500; Teton Homes 5er;
Native Texan - Transplanted Tar Heel
Retired USMC Mustang (LDO)
Semper Fi !
time2roll
To reset a breaker it needs to be switched off firmly then back on. Breaker does not always look tripped.
But check the GFCI first.
ScottG
Jack Spratt wrote:
If you have a reel for your power cord that is one place to look.
Make sure you have power to each of the 25 amp legs.
The two legs of a 220V system are 50 amps each. 🙂
An excellent suggestion to make sure you have both sides though!
Jack_Spratt
Leprechaun 260 DSF
2017 Big Horn FL3750
'10 Yellow Lab to keep us on our toes.
DownTheAvenue
2. You may have a tripped ground fault outlet. look at every outlet and if one has a ground fault trip device, merely reset it.
3. If you have 50 amp service, it is possible, but highly improbable that the main breaker only tripped on one leg. Turn off the main breaker and turn back on. Do the same at the park pedestal.
enblethen
You should have a least one more likely two GFCI receptacles. Galley and head are normal locations.
Did you reset any of the circuit breakers/
Hate to say it but go through the rig again!
Bud
USAF Retired
Pace Arrow
