Dec-04-2015 06:26 PM
Dec-07-2015 01:03 PM
Dec-07-2015 07:26 AM
pbmazda32 wrote:
Im curious about the EZ Flex.
Dec-07-2015 07:20 AM
Dec-07-2015 06:15 AM
Can you give me your thoughts on the suspension upgrade? Has it improved ride quality while towing? Do you consider it money well spent?
Dec-07-2015 06:02 AM
Dec-06-2015 10:57 AM
Dec-06-2015 09:27 AM
Dec-06-2015 05:32 AM
Old-Biscuit wrote:
Lost 2 tires on same axle.......at same time???
Rear suspension has been over extended due to carrying all the load
Will need to support axle, remove tire/wheel, remove leaf spring eye bolt at equa-flex, flip equa-flex back up into position and bolt up leak spring
Repeat for other side
Dec-05-2015 10:28 AM
Dec-05-2015 10:18 AM
Dec-05-2015 07:16 AM
dehaile wrote:
Hello. We lost two tires on same axle and had to tow trailer a couple of miles to get to town. We were towing on the rear axle at a very slow speed for just a small distance. After putting the tires back on, we noticed the equa-flex suspension is facing downward and not upward so that the axles are straight. When we lower the trailer, the equaflex hangers just pins itself to the side... still facing down. We did not unbolt the equaflex or the leaf springs. How did this happen? How do we fix? Will it happen again by just raising the suspension? Thanks
Dec-05-2015 06:50 AM
jmtandem wrote:
I would remove the one bolt that holds the EquaFlex to the frame and re-positon the hardware. It will be easier if the wheels/tires are removed from the axles first. Put a little jack under each axle between and under the U bolts and if you have a friend they can move the axle a little by hand and you can repositon the EquaFlex into position correctly positioning the /hangers. Then re-insert the EquaFlex bolt back into the frame. It is not a hard or involved task.
Dec-05-2015 06:41 AM
Dec-04-2015 08:11 PM
